Old 08-20-2009, 11:03 AM
DriverzInc DriverzInc is offline
If you are going with the Nitrous I's, then they are custom built, and you can pick backspace.
In that case, on an 18x8 and 20x10 set, I would suggest a 8" with a 5" backspace and up to a 255 wide tire up front.
Note: For a stock suspension, I would run a 9 with a 275, and more backspace, but for an AirRide set up, and for the sake of being safe, I would suggest the 8" with a 5".
For the rear, a 10" wheel with a 5.75, and my suggestion... go with a 275/40/20. This is wide enough to look good. Will give you all the clearance in the world for when you drop that sucker on AirRide.
Note: For a stock, or slightly lowered car, I've done as wide as a 305 wide tire on a 10", but again, to be safe, and to set you up with a wheel and tire combo that will definitely work before and after your suspension mods, I would suggest the 275/40/20.
Fyi: the Nitto NT05 comes in both sizes you need.
Hope some of this helps....
