Old 08-22-2009, 05:45 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
Man...the VSS stuff has been a headache - that unit above wouldn't generate enough pulse to feed the ECM.
So...after much research and debate.....the VSS is in......
I found the 4L80E reluctor wheel was just a tad loose over the splines. I hand machined four tapered slots into the wheel, then using four pins and lock-tite, I slid the gear in place and pressed it onto the shaft. I then yanked the VSS out of my 07 silverado to get an idea of how much air gap to set. I then wrapped five runs of tape around the wheel and slid the tail housing back on after I machined out the original speed gear hole to allow a straight on approach with the VSS sensor. Once the housing was back on, I wrapped the VSS in reverse tape, slid it in against the wheel, and filled it with epoxy. After that set, I slid the VSS out, and trimmed it off. I modified the mounting bracket and drilled/threaded the housing to hold the bracket tight. Took it all apart, removed the tape from the wheel - then slid it all back together. With my voltmeter on A/C current - I can spin the tailshaft and get voltage readings to increase the faster I spin it. I think we are good!
Old 08-22-2009, 05:46 PM
69MyWay's Avatar
Here is the other update - Oil pan modified - and on...and the trick new nylon fuel lines are made and ready to go.
Old 09-09-2009, 07:35 AM
69MyWay's Avatar
Here is the good and bad.
Good - we were able to flogged out the electronics and the engine with dbw throttle is all good.
Good - the air intake is taking shape - and almost done
BAD - after hooking the radiator up and getting it running - it is blowing water through cylinder 1 and 4 (both sides of the engine) and filling up the crank case.
I drained it all out - am going to finish building the air intake, then yank the body back off the frame and pull the heads.
My pics are too big to upload - will get something on the web later to share the disaster.....
Old 09-12-2009, 08:06 PM
70rs's Avatar
70rs 70rs is offline
Sorry to hear about the water issue. I hope it is nothing that reqires a new motor. Good luck!
Old 09-13-2009, 05:16 AM
69MyWay's Avatar
Here is the low down on the mow down.
The painless wiring is super high quality nice stuff and easy to work with.
got it all wired with the body off the frame so I had full access to do what I needed, then wrapped the harness purrrty.
Loaded up - radiator in place....and ready to test it all out - of course the engine failure was already present - I just didn't know it---yet.
Then I noticed pressure in the radiator - I never got the engine over 190 in the drive - and it spit water out of both exhaust manifolds.
So...we drained it out.....
cappuccino anybody????
Here is what I found - BOTH head gaskets blown - how weird is that? I'll get the heads to a machine shop this week.
I went ahead and started the cold air intake build - it is looking good - but going to be a super tight fit. The air intake goes over the radiator support down the front to a 10" Anderson Performance filter....
Waiting on headers now too - but will work on getting the engine healthy before they get there. I'm actually on a schedule...have to have this flogged out and functional before December. The final report will be in the March 2010 Corvette Enthusiast magazine with all the details of how this thing went down.
Now....I have an eye on a Comp cam xtreme energy cam...some roller tip rockers...and of course we could do a little head work while we are at it. However, I planned on running it stock first - spinning the dyno to figure out what we have as a base line - may be denied that opportunity now.
