Old 08-24-2009, 06:56 PM
Musclerodz's Avatar
probably not far off then. A lot of work to do a full floor and trunk pan
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-24-2009, 07:18 PM
jcal87's Avatar
jcal87 jcal87 is offline
o ok i heard dropping a floor pan in was pretty easy glad i didnt attempt it myself
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 08-24-2009, 08:15 PM
Rick D's Avatar
Rick D Rick D is offline
Doing the full one piece floor is not hard but does take alot of time. If you have basic skills and time than I say do it yourself. Lots of spot welds to cut so make sure you get a good drill and a good spot weld drill bit DO NOT use the Blair bits. If you do make sure they are strait when you drill or they will brake. The ones I use are from Dent Fix for standard drill set up. As for pricing not bad $50.00 an hour is not out of line. Some shops charge more some shops charge less, in the end it's the quality of the job that counts.
Rick
Old 08-24-2009, 08:21 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
I thought the full floor was actually pretty easy. Overall, it took me about 16-20 hours including removing the existing one and prepping the rockers and painting them. The trunk pan took quite a bit longer for me because it was the first piece of metal I ever changed. One word of caution. DO NOT ORDER A 68 FULL TRUNK!!!!! Ask me how I know. It's stamped about 1/2" too short. If you're mini tubbing the car, just buy a 67 pan and you'll be fine. Even if you're not mini tubbing the car, still order the 67 pan and modify the driver side shock tower.
The quarter price sounds about right. There are a few areas on these repro quarter that need some attention. I can explain them to you and show you pictures if you need. You should still have my number. Call me if want. If not, PM me and I'll email you my number again.
Chris
Chris
Old 08-24-2009, 08:34 PM
almcbri's Avatar
almcbri almcbri is offline
I would go for it. Floors and trunk are very easy and this was the first thing I started learning on. There is some time involved like mentioned, but if you are halfway decent with a mig, I would give it a shot. Maybe if you feel comfortable enough after the floors and trunk you can tackle the quarters.
One thing I had to get past at the beginning was having to trim and cut up the brand new pieces, they all need work to fit just right.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 08-24-2009, 09:44 PM
jcal87's Avatar
Chris
yeah i still got it chris I'm just deciding whether or not to do it myself or not because i would have to buy the tools as well
1968 Camaro Blue
Texas A&M Alumni
