Old 09-14-2009, 08:08 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Looks pretty cool Mark
Autokraft
Old 09-14-2009, 08:15 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by ohcbird View Post
Rearend cooling pump there on the right mount?
Yes it is Weldon diff cooler pump mounted on the axle housing. I wanted it to be below the fluid level. They are a self priming pumps but I wanted to try it on the housing.
Mark
Old 09-14-2009, 08:19 PM
Mark
hey, just giving you some grief my friend. Car looks great.
Old 09-14-2009, 08:24 PM
Stielow's Avatar
I dip those pesky red or blue anodized fittings in DRANO CYRSTALS and WATER mixed up in a plastic bucket - only takes a very small amount to do one or two at a time... but you can only use CRYSTAL drano... it's sold in a small black can with a red plastic lid. About $3 for a can of it.
Dunk that fitting in there hanging off a piece of welding rod - swish it around and rinse it off in fresh water - and polish it right up.
If you make the solution too strong - it will fizz and boil and you better be quick on your dip! Also DO NOT PUT THIS CLOSE TO YOUR FACE either - the fumes are more than nasty! Make it too weak and it takes forever... after a couple of batches you'll get the hang of it.
EEEEEEEEHHHHHHHHHAAAAAAAAAAAA
You can use Easy-Off also
I stripped this fitting prior to welding it on my dry sump tank
Old 09-14-2009, 08:36 PM
Mark I've enjoyed reading about your build and learnesd a lot . But this is killing me I don't have my car here to try any of them . Sweet build.
Old 09-14-2009, 11:46 PM
Jr's Avatar
Jr Jr is offline
A little update:
I had added a few more items to the car and had Stenod do some work on the car.
Finished the exhaust, fuel lines and diff coolers line.
Can someone help me out? The lines on the passenger side are for the diff cooler, right? I assume that the line on the left will be the fuel line? Also, I assume that this will be a dead head fuel setup...like the corvette?
Old 09-15-2009, 03:35 AM
Stielow's Avatar
Lines on the pass side are 1/2" for diff cooler. I made them 1/2" due to the fact I'm going to the front of the car. The line on the left is a 3/8" fuel line. I put it on the driver’s side because the LS7 fuel feed is on that side of the engine. My first time making hardlines from scratch. It was fun if you have the right benders. I purchased Ridged benders off Ebay cheap. The 1/2" lines take some effort to bend.
Mark
Old 09-15-2009, 08:37 AM
Mark
I love the Ridgid stuff, they work great. Stainless can be tough to bend, gets pretty stiff in the 1/2" size. I learned on aluminum............
Old 09-15-2009, 09:13 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Looks awesome Mark. Keep up the great work.
Old 09-15-2009, 05:22 PM
customcam's Avatar
Love it. Mark show us the wheels lol
Really Mark you are a pioneer in the car building game and an inspiration
