Old 09-15-2009, 07:11 AM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
315 40 19 tires with 19x12 in the rear.. 255 40 18 tires with 18x9 in the front
Love the stance - what size tires are you guy's running.
Old 09-15-2009, 09:16 AM
syborg tt's Avatar
Thank you - looks perfect
marty-mj
Old 09-15-2009, 09:35 AM
youthpastor's Avatar
Looks good!!!
Old 09-20-2009, 04:08 PM
GHOSTDANCER GHOSTDANCER is offline
Old 10-01-2009, 08:18 AM
OneCamaro OneCamaro is offline
Default Back spacing (front)
What back spacing did you do with this wheel and tire combo? I have the same sub frame and engine combo. Did you try a 275?
Did you use the factory A/C bracket? And are you using vintage air?
How far back did you have to cut the shifter hole from the original location?
Thanks in Advance, nice to see your build. Great Job.
P.S. Great machine work and I love what you did with the sub frame connectors.
Old 10-01-2009, 07:24 PM
Cris@JCG's Avatar
The front offset is 18x2.5 outer & 18x6.5 inner as I gave it to Forgeline.. I don't have it it on paper for the rear but will get it for you when I have the wheels off the next time..
Did you try a 275? No.. But I am sure it will work will max offset..
Did you use the factory A/C bracket? My machine shop made the brackets to mount the A/C compressor that was given to us by Vintage Air @ the time.. Now the have a smaller A/c compressor
I wanna say about 2 inches..
Thanks in Advance, nice to see your build. Great Job. Thank you!! We try to come up with new cool things!
