Old 09-17-2009, 07:10 AM
I would call the oil pan manufacturer. A 540 has 4.25 stroke and maxes out many pans on the market.
Old 09-17-2009, 07:29 AM
I'm running one on my 427 SMALL block... can't imagine NOT running one actually - the more crank you have swinging around the more you need some oil control... IMHO
Old 09-17-2009, 09:46 AM
ohcbird's Avatar
ohcbird ohcbird is offline
Default windage tray
If you already have the basic screen, you should start with that. Like Vegas69 said, you're going to want to make sure it clears. Most rod bolt heads / nuts on 4.25" cranks hit the screen type trays, but they are easily modified.
Old 09-17-2009, 10:34 AM
windycity1 windycity1 is offline
The Milodon pan that I am using is the same one that originally came on the engine, so it should be okay.
