Old 07-17-2009, 02:58 PM
g356gear's Avatar
g356gear g356gear is offline
Got the car into the alignment shop today. Everything was pretty close on the laser machine. I was out about a 1/4" on the rear with the alignment and about the same on the front. It needed a good amount of shimming to get the cars camber/castor sorted out but it drives pretty nice now. The prodigy bar seems to be pretty good riding compared to the stock leafs. Much stiffer and more planted ride than before. My stock seats I think are going to be an issue with hard cornering. I already feel myself bracing against the door panel and console.
Old 08-10-2009, 07:17 PM
g356gear's Avatar
Went for a drive the other day and broke a rocker. Luckily I got the car shut off before it did any damage or came apart.
Pulled everything apart and found a bent pushrod and an oiling problem from another.
So I picked up a set of Comp Magnum Roller Rockers, new 3/8" pushrods and guide plates.
With the taller rockers, I then had to change to a taller valve cover,and went to a fabricated aluminum unit.
They don't seem to take power brake boosters into account with these, so a little cut and re-welding and everything clears OK.
Old 09-20-2009, 08:31 PM
g356gear's Avatar
I picked up a set of Lemons Big block headers off a forum with 250 miles on them for a pretty good deal. I had blown a hole in my #4 cylinder header pipe and needed to get new headers anyway so the timing was good. They are a 2 1/4" pipe header with individual pipes and a 4" collector. They were ceramic coated and had O2 bungs for FI or fuel injection when it comes time for that. They fit super tight and some of the clearances are within 1/8". I had to trim my motor mounts for clearance on both sides and remove 1 grease fitting off my suspension to get full lock to lock without contact. No biggy but they are that tight.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 09-20-2009, 08:35 PM
They look good in there. Very nice.
Old 09-21-2009, 08:24 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Big difference in headers there. LEMONS makes some rally nice headers.
That should help the exhaust move quicker. They do look a little tight in there, but as lonk as they fit.
Old 09-21-2009, 11:55 AM
g356gear's Avatar
The quality is great but they leave almost no room for any variation between cars. Some of the steering parts moving lock to lock come within 1mm (1/32nd) of contact, it's that tight. I have a couple wear spots on the headers where there was rubbing from the previous owner and hea was running the same year car with a BBC. Anything bigger than 2 1/4" piping I don't see how they would ever fit.
Old 12-20-2009, 12:18 PM
g356gear's Avatar
I finally got the new air cleaner and new plug wires in to work with the Lemons headers. Still not sure if I want to paint the valve covers and air cleaner or leave them in natural aluminum finish.
Old 12-20-2009, 05:52 PM
tones2SS's Avatar
Thumbs up
Looks awesome.
The air cleaner and valve covers would look good in black!!
Old 12-20-2009, 06:50 PM
syborg tt's Avatar
great project - thank you for sharing.
marty-mj
Old 12-21-2009, 09:30 PM
g356gear's Avatar
Looks awesome.
Thanks guys. If I do paint them it would probably be a gunmetal to match the wheels. Plans are to go to an aluminum Weiand dual plane stealth intake this winter.
