Old 10-24-2009, 03:41 PM
pro-touring.no's Avatar
pro-touring.no pro-touring.no is offline
Default 2 gen camaro front suspention
Hi I want to use 18x10 7"backspace wheels with 275\35tire on original sub frame on my 70 camaro, what must i doo to get this rigth?? I have also wilwood 6 piston cliper and 14"rotor.. is there anyboy out there who can help me with what i can do to get this done and parts that I need do solve this.. thanks..
Kjell
Old 10-25-2009, 08:41 AM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
Supporting Vendor
7" bs will not fit very well it will hit the sway bar and upper control arms, use a 9" wide wheel with 6" bs
www.pro-touringf-body.com
Old 10-25-2009, 11:11 AM
Blake Foster's Avatar
Yea What he said
we tried that even with a drop spindle and it wouldnt work
Blake Foster
www.speedtechperformance.com
Old 10-25-2009, 12:32 PM
Originally Posted by killer69 View Post
what if you use dse upper and lower arm and new spindel??
and mody sway bar??
Old 11-05-2009, 12:10 PM
markss28 markss28 is offline
sounds a little like too much BS (back spacing I mean)
Never Stay Stock
Old 11-13-2009, 09:00 AM
and mody sway bar??
well i guess anything is possible if you want to modify everything, kinda hard to modify a sway bar tho.
we ended up with a 19x9 and a 275 on the black trans am the back space was 6.5 we used our upper and lower arms and Baer brakes with the drop spindle. our arms have adjustable steering stops to prevent the wheel contact. also the car is really low and we pulled the front wheels in a bit to get it that low
Blake Foster
Old 11-13-2009, 11:41 AM
70rs's Avatar
70rs 70rs is offline
I love the stance on this car. What is the rear wheel and tire set up?
Old 11-13-2009, 11:51 AM
Default love it...
this was a very nice looking car
I have the wheels..so I hope I can use them ...
Old 11-13-2009, 12:35 PM
rears are a 19x12 with a nitto invo 345/25/19
Blake Foster
Old 11-13-2009, 01:30 PM
I have a 10 1/2 inch x 18 on the front of my 72 but, the front is widened. The back space is only 5.4". I could have possibly gone 5.9 but it would be very close to the upper ball joint and any wider would hit for sure. I am using a Howe tall ball joint on an AFX spindle so that may not happen in your case but watch for it depending on the wheel makers lip. It will also really start to cut into your turning radius if you don't do other mods.
This is a pic of a friends wheel off his vette on my car with a spacer in between to keep it from hitting on the upper ball joint.
