Old 11-23-2009, 07:26 PM
customcam's Avatar
Amazing Just amazing
In the render you have Hre Wheels is that what your going with?
Old 11-23-2009, 07:32 PM
War's Avatar
War War is offline
Probably, it's not set in stone yet. Wheels/Tires, Brakes and shocks are the last things I need to get.
Jason
Old 11-23-2009, 07:34 PM
War's Avatar
War War is offline
Couple pics of the trunk pan and hinge supports.
Jason
Old 11-23-2009, 09:19 PM
bentfab's Avatar
bentfab bentfab is offline
Question ? On your panels are you useing a male female buck and press ? Bead roller ? Or tracer buck on a pullmax ? Or what ever else you have up your sleeve ? I think I'm going to change a few things on the Cuda I'm builbing after seeing your work. Very inspiring.
Mark
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 11-23-2009, 09:31 PM
phillym5 phillym5 is offline
Finally you put this thread up....
Im thinking this will be the baddest 69 yet!!
I really can't wait to see what else your going to do with the car.
Old 11-24-2009, 06:24 AM
DOOM's Avatar
DOOM DOOM is offline
Jason I went through your build thread and have a question... Can you tell me what method you use for closing or opening the body gaps.
Mario
USCOLLISION
Old 11-24-2009, 04:15 PM
War's Avatar
War War is offline
1/8" round bar and welder for closing, grindin and weldin for opening. There alot in of steps and it takes alot of time. I hammer and dolly edges as flat and thin as I can get before adding or removing material. On edges of quarters and such if there soft I will cut and add rod to get a sharp edge. You have to go slow and take your time with lots of hammer and dolly work. I seen some guys make a mess out of panels. Pacual said you can have your gaps out of bondo or metal, you choose.
I had to re-skin both doors and I fully welded the inside so there are no seams
Here is some pics of the doors
Jason
Old 11-24-2009, 09:47 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
I have the same questions? Also, will all the body seams be smoothed?
Mark
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
Old 11-24-2009, 09:54 AM
groovyjay's Avatar
groovyjay groovyjay is offline
This car is shaping out to be my favorite 69 Camaro ever!
Old 11-24-2009, 04:23 PM
War's Avatar
War War is offline
Most of the seams will be smoothed
Jason
