Old 11-26-2009, 09:48 AM
bhume bhume is offline
Default Fatman front subframe
http://cgi.ebay.com/ebaymotors/ws/eB...CA:MOTORS:1123
Old 11-27-2009, 11:05 AM
TexasSixShooter TexasSixShooter is offline
Default Subframe
I'm very interested in the subframe. Are there any parts that need to be complete except for the brakes? Does it come with transmission mount? What about the engine mounts? You said the springs were setup for a big block? What kind of spindles reg or 2" drop? Does it come with a sway bar? If not can any aftermarket fit? I would need assistance with shipping if you would help out that would be greatly appreciated. What made you change your mind with the sub frame change?
Old 11-27-2009, 05:52 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Per board rules you must list a price!
Brent
Old 11-27-2009, 06:01 PM
camcojb camcojb is online now
true, but if the Ebay ad has a "buy it now" price we let it slide.
Old 11-27-2009, 07:14 PM
the sub will accept factory GM brakes or aftermarket, the sway bar is included just not mounted for the pics,the spindle is a 2" drop and I think if installing a small block you use the factory mount, if a bb fatman has a modified mount, the crossmember was setup for the stock mount. I removed the 2 tabs because I was installing a t56 setup but would be very easy to install the mount bracket to accept stock and yes I will assist in shipping. sorry for not posting the price on here as I did not know I had 2 but I am looking to get 2700.00
[email protected] and thanks
