Old 11-28-2009, 10:26 AM
phillym5 phillym5 is offline
I don't have a day "planned" for the track... winter is just about here and the tracks are closed now. But here in my "Michigan" world and car scene... you can't have a fast car with out running it. You'll get haggled something serious.. so i will have to run it this spring.
Real problem is... it only has a 4 point cage.. no chute... no fuel turn off...ect. So i'll probably only get one pass.... even though im good friends with the track manager... and he lets things slide... going more than 150 through the traps will be pushing it. Maybe we will rent the track this spring.
And yeah.. 335 19's.
How much boost are you running right now??
Greg... I have to stick to skating... how else would i pay for this crap!! You know im just a "Dirty Ghetto Kid"!!
Old 11-28-2009, 10:32 AM
Come on out and we'll run em down the track together. I still need to get min out to the 1320.
Old 11-28-2009, 11:18 AM
[/QUOTE]Greg... I have to stick to skating... how else would i pay for this crap!! You know im just a "Dirty Ghetto Kid"!! [/QUOTE]
Yeah right! Love ya buddy -- have fun with that Camaro... I'm dyin' to see that KB video!
Old 11-28-2009, 01:44 PM
Yeah I hear ya... or if you aren't hooking up just let out of it and brake til you get that really good pass and give it all its got. Knowing the track mgr sure don't hurt!
I'm only running about 10psi now, but this motor and block have seen 14psi when it hit 700rwhp when previously dyno'ed.
I'd really love to crank it up to 20psi.
Old 11-28-2009, 01:49 PM
awr68's Avatar
awr68 awr68 is offline
Did Jody run a differant pulley to hit 14psi?
Tony
'68 Camaro
Old 11-28-2009, 02:03 PM
Nope, same pulley but we have an intercooler setup which we figured would result in 2-3 psi drop max, but we are seeing 4-5 psi drop lately. So we are going to check for boost leaks and try to test boost at the procharger on the dyno day and see what the deal is. Something is definitely going on....
Old 11-28-2009, 02:09 PM
awr68's Avatar
Might have to change the PC pulley to make up for the IC drop? Keep me in the loop on this...I may have the same corrections to make!
Tony
'68 Camaro
Old 11-28-2009, 02:14 PM
Absolutely. I hope there is just a leak somewhere, otherwise a smaller pulley will be in order to dial up the boost.
What psi are you targeting for yours?
Old 11-28-2009, 05:41 PM
awr68's Avatar
We (Frank) only gave ATI a hp goal, not sure what psi we will hit until I look at the boost gauge. I may play with pulleys down the road...but if we hit the target hp I will leave it alone and just work the bugs out of the car first.
Tony
'68 Camaro
Old 11-28-2009, 02:15 PM
6D9 6D9 is offline
When are you hitting the chassis dyno?? That would be way cool to go down to Vegas and run the 1/4 with Todd.
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
