Old 12-01-2009, 05:41 AM
PRRC PRRC is offline
We have been ask to provide a little more info. On the battery's. So here you go. One of the biggest benefits in my opinion is the size of the battery it self. When relocating a battery your options were limited because the size of the battery's. So the trunk was the most likely place to get them out of sight. Then you have a ton of cable routing to do. These little Braille battery's can be hidden in the the engine compartment behind a close out panel or on the frame rail of a street rod or PT car for that matter. mounting them close to your run source eliminates all the cable routing problems and extra cost.
1
Cubic Horsepower
At under 22 pounds, the B3121 is our lightest do everything battery yet. Using our Advanced AGM racing technology we have put a lot of power into a very small package. With 1380 pulse cranking amps this has enough power to start more than any other battery in its weight class.
3
Exclusive Dual Terminal Design
A Braille Battery exclusive! This feature allows the battery to be mounted in a variety of positions. It is designed to accept racing, power sports and automotive terminals vertically and horizontally.
5
Exclusive Brass Auto Terminals
Included with every Braille Auto Battery are patent pending high quality brass SAE terminals. Designed to distribute the electrical load into and out of the battery. Designed for high amperage, high stress use of racing and audio competitions.
7
Solid Top Lead Connectors
Shaken, not stirred - From 6 "G" NHRA drag launches, to 4 G cornering loads in Indy this design holds the internals firmly in place.
2
No Spill, No Corrosion, No Maintenance
Technically registered as a "sealed valve regulated" design, this patented technology completely eliminates acid spills and corrosion on terminals. This design is environmentally safe does not need filling and maintenance. Air shipping approved.
4
Stainless Steel Terminals
Stop loose battery connections with our robust stainless steel threads. These heli-coil design threads allow higher bolt torque and help keep your battery connected even in high vibration environments.
6
Green from Start to Finish
We employ a manufacturing process with the highest concern for the environment and quality. Recycled lead, plastic and stainless steel ensure we'll have a future to race towards.
8
Performance Certified - Fully Charged
Every Braille Battery is individually tested and certified before shipping, eliminating DOA batteries. Fully charged and ready to install at time of shipping.
www.paradise-road.com
Old 03-03-2012, 05:10 AM
Coursey Coursey is offline
What is pulse cranking amps vs. cold cranking amps?
Also how does this battery handle things like A/C, EFI, CD Ignition, and sound systems?
