Old 12-10-2009, 02:28 PM
RobG RobG is offline
Thanks Tobin
Old 12-11-2009, 08:12 AM
Apogee Apogee is offline
Originally Posted by RobG View Post
Thanks Tobin
De nada. Let me know if you have any problems finding what you need.
Tobin
KORE3
www.kore3.com
Old 12-12-2009, 05:23 PM
Question
Just one more dumb question..
Are the C5 and C6 caliper bolts the same?
I have a set of C5 brakes lying around with all of the hardware.
Old 12-14-2009, 06:31 AM
Yes, the C5 and C6 mounting hardware is the same to the best of my knowledge. While the knuckles have different part numbers, the mounting points and thicknesses for the brakes are identical between them. Front and rear caliper pad abutment brackets are interchangeable as well, so you should be able to use what you've got.
Tobin
KORE3
www.kore3.com
