Old 12-24-2009, 06:36 AM
nvr2fst nvr2fst is offline
Rich, Try to locate a damaged Mazda Rx8, the sliders on the 09 models I believe are different than the previous years which should be all the same.
They come with Recaro seats
Old 12-25-2009, 05:00 AM
67ragtp 67ragtp is offline
Thanks Dave- I will look in to it.
Merry Christmas - Rich
Old 12-27-2009, 06:08 AM
Jon69RagTop Jon69RagTop is offline
Default Wedge Engineering
Hey Rich
Try this: http://www.wedgeengineering.net/
They make all sorts of seat brackets.
Jonathan
Old 12-27-2009, 03:04 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Hey Rich,
I've got the Wedge engineering seat brackets, and they work just fine. Only minor complaint might be that some modification may be required if you want to drop the Recaros down all of the way as the seat belt bolts hit the mounting bracket on the seat if you've got it on the lowest setting. Its hard to describe, I can get you pictures this week if you like. Regardless, if you're worried about height, they still sit pretty low on the middle setting.
Matt
Old 12-28-2009, 05:07 AM
Originally Posted by 69MSA View Post
Hey Rich,
Matt
Matt- If you have time pictures would be great- Thanks Rich
Old 12-31-2009, 06:07 PM
Matt@BOS's Avatar
Finally had a chance to get some pictures for you Rich. I had forgotten that the passenger side bracket cleared the bolts by a hair, and that is what I got a picture of. If you don't have carpet padding around the area it should all fit fine. Took a couple so you could see about how high the seats are. The driver's side which is sitting on the middle height might be half and inch higher, if that.
Matt
Old 12-31-2009, 07:17 PM
Matt- Thanks for the pics it really helps understand how it all fits, BTW the car came out fantastic
I ordered the recaro speed s seats in all black vynal and the sliders and brackets from Wedge, he gave me a great price on everything.
Thanks again, appreciate you taking the time to shoot the pics- Rich
Old 12-27-2009, 10:43 PM
T-Type T-Type is offline
the recaros only come in a specific model...it may have been the WS3 package....for some reason that sounds right....however i'm probably off. just an fyi.
edit: i just checked.....it's the R3 package.
