Old 01-03-2010, 08:35 AM
6spdcamaro 6spdcamaro is offline
As far as the shifter being located too far back, keisler engineering makes kits to move the shifter to any position you want. You could probably contact them about some of your other issues also.
Kenny
Old 01-03-2010, 08:40 PM
68LS1's Avatar
68LS1 68LS1 is offline
Kenny
If you need everything I would suggest speaking with Keisler also. Kit looks very complete. The Perfect Fit kit looks like it puts shifter in right spot
http://www.keislerauto.com/
cheers
Roger
68 RS Camaro Convertible LS1 6 speed
72 C10 SWB Stepside, old skool 350 4L60e
71 K5 Blazer 350sbc T350
Old 01-04-2010, 05:22 AM
NRV2L8 NRV2L8 is offline
Thanks for the input guys.
Anyone have any comments or used the TR6060 trans yet. Know if it's a P.I.T.A. to deal with / install in an F-Body?
Again, Thanks for any replys.
Marc
Old 01-04-2010, 12:54 PM
i could be wrong but i think a tr6060 is a little bigger than a t-56 so there might be clearence issues. I'm putting a tr6060/ls1 in my 68 within a month so i'll let you know what it takes to put one in. Good luck
Ken
Old 01-04-2010, 03:24 PM
Ken
Thanks Ken,
I look forward to your follow up.
Marc
Old 01-07-2010, 08:31 AM
A little further research is telling me that I face 2 issues with using the TR6060 in a 69 Camaro. First is the Shfter location and second is the Yoke / Drive Shaft mounting point.
Keisler, does offer a complete kit but at $3,675. It's a bit steep for me as a one shot deal. Probably end up spending that amount anyway to get the TR6060 to work. Can't these mods ever be affordable? I know the answer to that but wanna whine a bit anyway.
Old 01-07-2010, 09:40 AM
Steve1968LS2's Avatar
I have a f-body T-56 for sale with a couple thousand miles on it.. it will bolt right up to an LS3 with no hassle.
$1000 plus shipping..
Then just buy the install kit from Keisler.. It's not a refined as the Magnum but it will be nearly $2k cheaper.
