Old 01-04-2010, 05:49 PM
RPM HOTRODS's Avatar
RPM HOTRODS RPM HOTRODS is offline
Originally Posted by TravisB View Post
upper control arm looks very short probably based off a mustang II design if I had to guess. And a 4 link rear.
Were the rear wheel openings moved rearward to retain the quarter windows? Whats the rocker hieght front and rear and desired ride hieght?
The front is based off a Mustang II, Heidts made the front, The control arms are about 8.25" from the center of the ball joint to the center of the rod-end with adjustments both ways, 4 link rear, Speedway style front and rear swaybars Rocker height is about 3.75 behind the front wheel and about 4 in front of the rear tire. The quarter glass took a little work. But we got them to work perfect. We notched the tubs just a pinch and reworked the tracks slightly and it all worked out. It was nice to work that out while the tubs could still be removed. But the opening remain in the stock location. Travis do you still have the dually?
Old 01-05-2010, 07:11 AM
TravisB TravisB is offline
No I traded it awhile back. Im building a 62 nova now....
Kenny Davis Hot Rods
Old 01-05-2010, 08:33 AM
Kendall Burleson Kendall Burleson is offline
kILLER JOB AGAIN MORE PICS. lOVE THE STANCE
Old 01-05-2010, 02:58 PM
Heidts#14 Heidts#14 is offline
BUZZZZ!!!!! WRONG. Please do not affiliate this subframe with mustang II geometry . It is a modified version of our Camaro Pro-G subframe .
Old 01-05-2010, 04:50 PM
yeah, if you want to get Chassisworks wound up say the same thing about their g machine front clip...........................
Old 01-05-2010, 08:04 PM
Glad you chimed in.... how about some specs on the front...?
Camber gain per inch?
Caster?
Instant center
Scrub?
RC?
Old 01-05-2010, 08:49 PM
Boy..... I didn't realize I could get in so much trouble on here. One mistake and everyone is on my butt!!!! And the bad thing is that I knew what it was. That is what happens with 14 employee, 10 projects, 3 kids and twins on the way. I finally think I may be loosing my mind. We do have some mustang II spindles on Ebay. I guess I could always say the damn chassis builders didn't give me a clue on what I got from them!!! SORRY it will not happen again.
Old 01-05-2010, 08:56 PM
Few with the wheel off.
Old 01-05-2010, 09:12 PM
The pictures weren't the greatest on the last one, so here are a few more.
Old 01-05-2010, 09:17 PM
Some of the interior, trunk sheet metal work along with the cage work.
