Old 01-17-2010, 12:01 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Default Dry sump for LS2
Just an idea Steve, since you are getting a new crankshaft for the new motor why don't you get it with an LS7 snout to run the LS7 oil pump, timing chain cover, oil pan, & run an aftermarket oil tank!!!! The harmonic balancer should also work with your current drive you have?? If not just get an ATI dampner & we will machine a crank pulley for you.. If I was building an LS motor from scratch.. This how I would do it GM spent a good chunk of $$$ to develop this dry sump system!!
Old 01-17-2010, 12:13 PM
Steve1968LS2's Avatar
Because I'm a less is more guy and every pound I add to the car kills me. Plus I've had zero oil issues with my modded Canton pan, even at sustained 1.2+g left and right turns. Also, the LS7 pan won't clear my rack unless I raise the engine and that's a non-starter.
Old 01-17-2010, 12:16 PM
Good to see the brake line clamps are Penny worthy!!
Maybe this hood catch might look good also!!!!
Still have my shipping address???? lol I only see one problem. Since they are thicker where the bolts go through it might hit my DSE closeout panel. As it is I have to use rounded allen bolts and they still almost touch. Ideas?
Those are so sweet.. you're really making some nice stuff Cris. We are doing a billet guide and you should feature something very unique like this in it. I will call you about it. Get that website done!
As for your brake line clamp. After seeing this I will never again weld brake line tabs to a housing. With these I can rotate and slide them to just the right spot. Here's a shot:
Old 01-17-2010, 12:42 PM
Cris@JCG's Avatar
I will have to see what we can do to to clear The DSE close out panel.. I have one here @ the shop..
Thanks for the compliments on the billet stuff!! Let me know when guys are doing the feature story & will get you what I have.. Now I have stop crusing the forums & get back the txt for my website.. That is my hang up with the site
Old 01-17-2010, 01:34 PM
eville's Avatar
eville eville is offline
where do i get some of those brake line clamps?
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
Old 01-17-2010, 02:21 PM
Cris@JCG's Avatar
Sent you a PM.
Old 01-18-2010, 11:08 AM
ScotI ScotI is offline
x2 .
Old 01-19-2010, 04:19 AM
legend legend is offline
would adding some of the Nelson racing throttle bodies see over 700bhp on that engine spec?
Old 01-20-2010, 01:25 AM
1970camaroRS 1970camaroRS is offline
This car is like a supermodel. Every thinks it's the sexiest thing in the world and couldn't be more perfect...but someone somewhere isn't happy with it.
Old 01-27-2010, 11:58 AM
Got a couple of Best Of Show spy shots today of the new inner fender wells..
