Go Back   Lateral-g Forums > Technical Discussions > Trucks
Old 12-09-2009, 11:15 AM
70rs's Avatar
70rs 70rs is offline
I think it looks better with a remote mount. What's the scoop on the 5.3? It looks great but what did you do inside? Nice project you have going.
Old 12-09-2009, 12:25 PM
tobenk tobenk is offline
I had two blocks but one had a burnt main and the other one had a messed up cylinder so i decided to bore it 30 and go with the cubes.
ARP rod bolts
TSP stage 2.5 heads
Comp Cams R roller lifters
TSP chromemoly 7.40 pushrods
ARP headbolts
TSP 224R Cam 224/224, 581/581, 112 LSA
IN motion double roller timimg chain
Victor JR intake
90 degree sheetmetal elbow
90mm fast throttle body
1 3/4 stainlessworks headers
Hopin for 400 or more hp.
Old 12-09-2009, 12:39 PM
70rs's Avatar
Sounds pretty stout. I am going to guess that you break the 450hp mark with that combo depending on your compression ratio. Do you know where that ended up at?
Old 12-09-2009, 05:52 PM
A tic over 10.5. I'm goin to have run good gas but not my dd so it won't be that big of deal.
Old 01-27-2010, 11:10 PM
70rs's Avatar
How is the project coming along? Have you had a chance to get that engine fired up yet?
Eric
Old 01-28-2010, 10:59 PM
It's goin slowly here lately been workin my butt off at work which is good i guess but not so much for workin on the truck. I been tryin to find brakes for the front but nobody makes any i like except the big 14" 6 piston that i cant afford. Im takin everything off of it to get frame powdercoated and to paint firewall and underside.
Attachment 22546
Attachment 22548
Old 01-28-2010, 11:04 PM
No i have not had a chance to fire engine yet. I am re wiring the entire truck and i havnt decided what ECM to run yet. I been thinkin Big Stuff 3 but idk. Thats alot for a computer but it can control trans to so i will see. Thanks for askin thou.
Old 03-20-2010, 06:24 AM
PASD U PASD U is offline
Nice build. Why are you having to rewire the truck?
I'm hoping to one day drop an LSx into my dad's '90 so I'm trying to collect all the "To Do" list stuff.
Old 03-20-2010, 12:26 PM
70rs's Avatar
Save some money and see if you can tweak a stock GM computer enough to run it. And the trans too. No need to blow the cash on the BS3 unit if you don't really need it.
Eric
Old 03-20-2010, 08:18 PM
Muscle Car PWR Muscle Car PWR is offline
Running the Mega Squirt computer on Op Muscle Truck
