Old 02-05-2010, 01:05 PM
Fluid Power's Avatar
If it is a sensor issue, what is the purpose of installing the metal shim?
Darren
Old 02-05-2010, 01:13 PM
James OLC's Avatar
Darren
Dollars vs cents (or sense)
My fear is that if it is a software or sensor issue that there will be a huge over reaction that ends with some stupid law outlawing the modification or alteration of FBW pedals or ECMs across the board.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 02-05-2010, 01:36 PM
69MyWay's Avatar
69MyWay 69MyWay is offline
That would be a nightmare in more than one way. Namely, the DBW system is center stage in Active Handling that will be required on ALL new cars sold in the US soon.
They may outlaw magnetic field sensors - if that is what they find to be the problem. That would leave GM, Ford...etc, in the clear since they don't use that technology.
Old 02-05-2010, 02:28 PM
dollars and sense does not answer the question at hand. What is the purpose of doing the recall and installing a shim that "helps reduce friction?" Is it to buy time and fix the EMI problem and then replace all the affected assemblies again?
Darren
