Old 02-06-2010, 08:26 AM
Normally it's more low end torque and slightly less high end horsepower.
Old 02-06-2010, 08:33 AM
Nowhere in Steve's math did he mention ROD RATIO.... and I always thought that this was important. I've actually been thinking of de-stroking the 427 because it has such "bad" rod ratio (4.125 bore - 4.00 stroke - 6" rod)
Is this no longer an issue with the taller decks of the LSx ?
Steve --- LOVE the updates -- like Eric said - it's fun to live vicariously.
Old 02-06-2010, 08:46 AM
ohcbird's Avatar
ohcbird ohcbird is offline
Todd-
Yes, for the same heads / cam combo & just a stroke change, that's generally true. Due to most new LS heads & 4 valve heads, that isn't necesarily the case anymore. Regardless, the engine is always about the combo rather than the resume of it's parts.
Old 02-06-2010, 08:47 AM
Steve1968LS2's Avatar
It is.. but again after talking with Brian Nutter at Wiseco he feels his piston design will be good to go. My rod choices consist of one size. 6.125.. At least from the Lunati catalog that I'm dealing with.
We will see if they are right
Yep.. and to be honest that's really goal. Personally I didn't want anything bigger than a 440, but the 454 just sounds so damn sexy.
I'm going to cam it down so that it still has a great street idle. I guess you could say that I'm going to size the cam like the engine is a 440 and the extra displacement will help smooth stuff out. I would be happy with 650/600 but after running this 440 last week I think it might be more.
Old 02-06-2010, 09:04 AM
ohcbird's Avatar
A few good cubes are always agood thing.
Old 02-06-2010, 09:43 AM
Never met a cube I didn't like. lol
I figure if Jackass and Blue Bomber can hook up 700-800 hp then I can hook up 680..
And the lack of a weight penalty is a bonus...
Old 02-06-2010, 09:42 AM
I was considering doing an undersquare engine as well. I have a bore size of 4.280. My block will take a 4.375 stroke. Ultimately my engine builder didn't feel it was a good trade off in power vs. cost and longevity. I had to ask myself, why don't you see them in any high performance application from the factory? The only conclusion I had was longevity and warranty. I ended up with a 4.25 stroke with a 6.385 rod. Another thing is big block stuff is heavy and they are harder to turn rpm with. Adding more low end torque and less high end hp didn't make sense for me where it may very well for you. I love this stuff.
Old 02-06-2010, 09:47 AM
Because the factory uses inferior parts for the most part.. they certainly don't use forged cranks and all the other goodies that make a reliable under-square engine possible.
You combo was just barely under-square with a ratio of .978 ... I don't think it would have been a huge issue so long as you have good parts, especially the crank.
And you're right, there's a big difference between a big-block and an LS.. seems like you can get away with more on the LS side.
Old 02-17-2010, 06:17 PM
Well, it doesn't feel like it but progress is being made.
The underside is scraped and the new Wurth stuff should be on there by tomorrow.
With any luck I should be picking up the rearend housing from powder this week as well, then we can put the rear back together and get her rolling again. Found that he axle tubes were pretty warped from the 3-link brackets so Currie cut off the ends and welded on new ones.. straight.
Parts are moving for the 460 cube RHS LS engine, biggest delay will be the 4.250 Lunati crank which is two weeks out. That's the only delayed part though.
Cam selected is a 247/261 .624 114 LSA stick.. Any guess as to power?
Should be good to go for having the car done by April.. knock on wood.
The LM clutch is over at Centerforce getting refubed (figured I might as well since it's out)
The oil cooler system is also in progress getting all hard lined up. The Setrab 925 fits perfect. This is being done at Fast Eddies Fabrication in Orange, CA.
Old 02-17-2010, 07:34 PM
scherp69's Avatar
scherp69 scherp69 is offline
Steve...is that an autorad setup? Your car is amazing
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
