Old 02-08-2010, 01:36 PM
One little "trick" --- with the glass rolled up and door shut -- you put a dollar bill (or in your case a $100 bill because that's all you'll have in your pocket) between the rubber (wubba) and the glass and you should be able to pull it out with little friction on it.... if you can't the glass is TOO TIGHT...
Also -- the newer 'wubba' tends to be harder than the factory stuff... and if that's the case a good seal is hard to get.
Old 02-08-2010, 10:15 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Excellent---ran into other issues now (surprise) before I can get to the window adjustment. Nick has graciously offered to walk me through it by phone as well--what a great community---I'll let you know what happens.
Doug
