Old 02-10-2010, 10:08 AM
Originally Posted by Junkie View Post
Because im going to try to go well over 200mph in the car. Im concerned with the heat those runs build up on a drag tire. Would you wanna run for an entire mile at full throttle on a drag radial or slick?
A lot of Texas Mile cars use R6's of some other DOT-R tire like that, but again, you're only going to find them in normal road car sizes.
Old 02-10-2010, 03:38 PM
Put more narrow tires on it for the mile. 345/35/18 is the only drag radial I know of that can do that. Viper Guys use them all the time.
Those wide tires will be anchors in the mile anyway.
Frank Serafine
Old 02-10-2010, 04:32 PM
Junkie Junkie is offline
Thats what im thinking. Run a really wide "street" tire and then have a set of dedicated tires for the mile
1970 C10, 1000hp street truck
2014 Viper, 800hp toy
1937 Ford, 500hp hot rod
1997 Supra, 1800hp race car
Old 02-12-2010, 08:01 AM
JayR JayR is offline
Lateral-G Supporting Vendor
Like Frank said, winding up a 20x15 to 220 will take some serious steam and your traction advantage will go out the window when your poor motor is trying to turn all that weight and mass at high MPH. Even the Veyron takes a super slippery car with traction control, AWD and 1000 hp to barely make 200 in a standing mile. A 12" wheel will work far better for top speed runs and will probably only require a wider rearend.
Old 02-12-2010, 12:26 PM
tyoneal's Avatar
tyoneal tyoneal is offline
You might want to contact the S.C.T.A. (Southern California Timing Association)
They are the people who run "Speed Week" at the Bonneville Salt Flats. They will certainly know who makes high speed tires and wheels.
Click on all the links that are associated with them, they are cool and very informative.
I wouldn't skimp on your research for this if 220 mph is in fact you goal.
Good Luck.
Keep us posted.
Ty
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
