Old 02-12-2010, 08:01 AM
g356gear's Avatar
g356gear g356gear is offline
Default Photos of hydraulic clutch install?
Hey guys ,
looking for pics of a hydraulic clutch install for a TKO or equivalent. I need to see how the pedal rod comes through the firewall and where the remote resevoir is located on a 69 Camaro firewall. With my Lemons race headers, I need to see where everything needs to sit and if clearances are going to be an issue.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 02-12-2010, 08:55 AM
Originally Posted by g356gear View Post
Hey guys ,
I modded an ATS bracket to use with my 69 Camaro big block and TKO. No issue at all with Lemons headers, which I also had (may not have been Lemons in this pic, not sure).
Old 02-12-2010, 11:57 AM
g356gear's Avatar
That was my concern. Here is what I have to deal with. The PS and PB may effect things with a hydraulic install.
Old 02-12-2010, 12:21 PM
asifnyc's Avatar
asifnyc asifnyc is offline
Default clutch box!
hopefully this will be helpful. I installed a hydraulic clutch master in my Javelin. I have power brakes and had to figure out a way to get the clutch master high enough on the firewall to be able to connect to the clutch pedal as close to the top pivot (where all the leverage is) as possible. my solution was to make a box that allowed me to bring the clutch master into the interior of the car a few inches. this tucks the remote reservoir clutch master up under the power brake booster. you can read about it here: clutch box install
Hope this helps.
-asifnyc- penngrove, ca (SF bay area) asifnyc.com - Javelin Blog
1974 AMC Javelin NASA American Iron road race car
1974 AMC Matador road race project
1975 AMC Gremlin shell
1973 AMC Javelin/AMX - street
1975 AMC Gremlin - street
1970 AMC Javelin shell
1962 Rambler American vert
Old 02-12-2010, 02:05 PM
g356gear's Avatar
I appreciate the info...that's a great idea! Unfortunately cutting up the car is not an option for me. If there was a way to mount the master under the dash, that would be ideal.
Old 02-24-2010, 02:31 PM
hotrod69camaro's Avatar
hotrod69camaro hotrod69camaro is offline
I'm pretty sure Hurst driveline in Carlsbad Ca has the stuff you need. I used it on my 69. give em a call
