Old 02-13-2010, 11:26 PM
deuce_454's Avatar
Originally Posted by mfain View Post
A couple of random thoughts on C4 IRS for your project. The C4 IRS "batwing" is easy to install in most chassis, but even the Dana 44 is fairly weak if you are going to abuse it (especially drag racing with big tires). Also, Chevrolet designed the suspension to impart a little "roll steer" into the geometry to "tighten" the car in hard turns to keep the back end from coming around -- a safety thing. That is partially why the links are so short (space in the C4 Corvette is the other). Also, you have a "loaded" half shaft that serves as a suspension link which is not especially desirable. That being said, a couple of advantages to the C4 set-up are that you can easily adjust the rear moment center and the camber gain for cornering and, if you make the four link front pick-up points adjustable, you can change the "hit" on the rear tire for drag racing and the squat/dive characteristics for road racing. You can't do either of these with a C5/C6 set-up without moving the rear control arm pick-up points. I solved the "weak differential" problem by going to a Tom's Differential C3 Corvette center section (12 bolt ring gear, 31-spine hardened stub axles, big spiders and side gears) on a custom built rear crossmember. There are also Ford 9 inch IRS center sections available. The Driveshaft Shop (and others) build extremely strong, custom length half shafts with 1350 u-joints. Tom's Differential sells cryo-hardened outer axles. I use 20-inch long forward links with heims and adjustable forward mounts that eliminate the roll steer. It takes a lot of work to make the C4 IRS live and perform well behind a big motor, but it is an option. I guess it just depends on how you are going to drive your car. Good luck with your project!
Those thoughts dont seem that random at all.. ive been researching IRS options for my 35 ford lately and have come to almost the same comclusions..
one of the very big plusses on the C4 is that since the half shaft serve as the UCA it wont require butchering the rear of the car to get it in there as would a c5/6
i dont agree that moving the trailingarms will affect the hit of the car like moving the arem on a 4 link.. and the reason fro this is that the trailing arms mount to the uprights and they do not absorb any of the forces involved in turning the wheels.. that reaction is handled by the longitudinal arm mounted to the diff case... the trailing arms only handle thrust from the wheels on acceleration and enginebraking, and the rotational forces excerted when applying the brakes..
all that being said, it isnt that bad a setup.. and it will polish nicely too :-)
If you want best handling from your c4, you will need to replace a lot or the rubber bushings with heims (as do gullstrand) to heep the bushing flex from changing the geometry in the turns...
im sure that a well engineered 3 link with a wattslink will be a more favorable setup for a car that sees occational drag racing.. if on the other hand you road race with roling start, you can't beat an irs.. the lower unsprung weight just keeps the tires planted more consistently...
Jake: Hit it.
Old 02-14-2010, 10:28 AM
mfain mfain is offline
[QUOTE=deuce_454;269182]
I do agree that you don't alter the tire loading effects caused by the rotational forces of the rear end by moving the front of the IRS 4-link, but you do change the instant center of the rear suspension. This alters the percentage of loading caused by mass of the vehicle on the rear tires during acceleration. Some circle track cars use this principle (moving the 4-link pick-up) to load the outside rear tire during acceleration. Most use a full floating rear end which, in effect, stops the rotational forces from transfering through the four link, much like an IRS.
Pappy
Old 02-14-2010, 12:18 PM
deuce_454's Avatar
[QUOTE=mfain;269225]
Pappy
exactly.. so its only the "lift" caused by "pushing" on a non horizontal pair of links.... so the antisquat effect is caused by the thrust acting over or under the C or G..
Jake: Hit it.
Old 02-14-2010, 04:59 PM
Sartren Sartren is offline
Well I'm only in the thought process of my build right now so I'll proly change my mind several times.
Old 02-14-2010, 06:57 PM
novanutcase's Avatar
novanutcase novanutcase is offline
If you need a point of reference go here:
http://www.stevesnovasite.com/forums...64#post1299964
Jasons already grafted a C4 front end onto his '63.....
John
Old 02-15-2010, 12:15 PM
Recently used this setup on a 58 vette with C4 rear transplant. Very easy to install. Didn't cost much either. Tray Walden is owner.
http://www.streetshopinc.com/c4str8axl.html
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 02-22-2010, 12:20 AM
deuce_454's Avatar
that is not a really well engineered package... its nice, but for a lateral-g car that gets beat on and driven... i wouldnt trust a shop that solidmounted the pinion like that.. and relied on the shockmounts for springs and bumpstop...
the corvette spindle isnt designed to carry the weight on the shockmount... and how on earth can you use a solid mount on the pinion of the diff case, when the rest is rubbermounted ??
the ladder connecting the tranny and rear end on a c4 isnt there to impede the exhaust, but to transfer the torque from the pinion...
a quick calculation... engine tq:500, 1.gear ratio:3.07, rear ratio:3.33 => wheeltourque:5111 ft/lbs... distance from pinion support to axle~1foot.. => load on frint x member in first gear 5111 lbs...
with the corvette ladder arrangement the distance is closer to 5 feet, and the resulting load is ~1000 pounds, wich is fine for a double sheer mount 3/8 inch bolt in a rubber bushing...
if the tube is a 40x3mm steeltube the moment of resistance is 1178, and the press is 5111 lbs = 22.7kN assuming the length of the x member is 1m the moment is 11.3kN/m the stress in the tube at that point is 9650n/mm2 = 1400ksi..
this means that the first time you get traction in first .. it will bend as you are far beyond the yield strength of weldable steel
if you were to do the same with a cantilevered spring or airbagged controllarm to cary the load where the spindle/upright is designed to ttansfer load... and some longitudinal controllarm to transfer the torque... youd be fine..
but doing an IRS install requires alittle grey matter activity
(alot of the street rod stuff out there simply isnt safe.. well its fine for a trailerqueen, but much of it is in the words of ralph nader "unsafe at any speed")
Jake: Hit it.
