I kept looking at the harness from Accel and looking at the firewall and seeing where and what I want to go thru for wiring and finally decided to call O'Reily's and see if they had some weatherpac terminal removing tools available. Low and behold they told me they could have them for me tomorrow
morning for just $16 and it is the complete set needed to to all of the types of connectors. I just couldn't see fighting with them to do the job since I am messing with an important part of the system and want to save putting another hole in the firewall.
If it all works out I will be able to pull the old hego wire back in the cabin and at the same time pull the new eugo wire in with them making all of the connectors inside the car. It will be a bit harder to change out the O2 sensor later if needed but I will have the tool to do it with or I can push the uego wires back out where the hego wires went thru and put the connector back outside. Decisions decisions.
Why Accel didn't just make it so there was a plug for the wideband on the main harness to begin with is still a mystery to me, they had a plug for damn near everything else I would never use.
With the way the engine wants to run I think I am going to be glad I spent the money for the widebands ability to have better control. It seems to really like 12.5 to 13 a/f to get going really crisp according to the tables.
I keep saving my tunes everytime I mess with it so when I get out on the road I can pull over and put one in and see how it runs compared to the other and hopefully I can mix the best areas together and move along faster with it once we put it under load.
The one thing that gets me is that the idle will be spot on to the idle settings in idle program one minute and then without doing anything and the temp staying the same rpm will go down? I keep thinking it could be injector decay because of voltage but it happens above 13 volts which I thought injector decay didn't start until it got below 12.5 volts. I may need to change my alternator crank pulley to increase my voltage at 900 to 1000 rpm idle to the 14.1 I get at 1200 rpm. It is around 13 volts at 1000 rpm. anyone else ever have this happen? Or will it more than likely just be I need to get a better idle tune to get it to stabilize?
I can only hope it is easier to know with the wideband installed?
I have my old 9 pin serial port/XP Pro laptop up and working again and it likes the serial port and it also works with the usb. The wideband will have to go into one and the ecu in the other to tune it so I hope it can keep up.
