Old 02-17-2010, 09:43 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Very cool. Nice rear suspension.
Keep us posted. Should be a great build.
Old 02-17-2010, 04:25 PM
colin204 colin204 is offline
Default Plans
Plans for the project:
- 6.2 liter All Aluminum L92 with LS3 intake
- Considering the TCI 6x automatic six speed transmission
- Ricks stainless EFI tank
- Art Morrison front subframe and subframe connectors
- Willwood Brake Package
- Forgeline Wheels
- Smooth firewall and relocated wiper motor
- Custom black interior
- Have not decided on exterior color yet
Old 02-17-2010, 04:54 PM
youthpastor's Avatar
wow...somday I would love to have a convert- thanks for the pics
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 02-17-2010, 05:03 PM
Sounds like a great set up. That 6 spd auto sounds like a nice option.
Matt Sweet car!
Old 02-18-2010, 07:09 PM
Default Next step in the project
Need some help from the experts. I am going to prep and coat the underside with a bed liner and need to make sure I have the steps correct so it turns out good.
1. Sand any surface rust that may be present on the non edp coated pieces such as the subframe and mini tubs (will 180 grit work?)
2. Red Scotch bright the areas to spray that have the edp coating or should I just use 180 grit?
3. Clean with waterborne wax and grease remover
4. Dry the panels and then wipe down with tack cloth
5. Spray SPI epoxy primer (How many coats?)
6. Seam seal all the panels (any recommendations or favorites for sealer?)
7. Should I put another coat of epoxy primer on and what is my time window from first coat of epoxy primer?
8. Apply bedliner coating (What is my window to put over the epoxy primer without having to scuff with red scotch bright?)
9. What are your recommendations for undercoating? I was looking at Raptor or SPI.
Please give me your input to the above info on what I am using and if I have the steps in the right order.
Colin
Old 02-20-2010, 07:42 AM
Default During the build
Here are some pictures during the build process:
Old 02-20-2010, 12:33 PM
Its nice when you can see how they went together.
