Old 12-07-2005, 12:26 AM
LSX are cool and sure can be bad boys, but HP to Weight to CI to Dollar, nothing beats a SB2
Old 12-07-2005, 08:47 PM
race-rodz race-rodz is offline
i figured taking advantage of the millions of $$ r&d work for some slightly used parts was deffinatley the way to go, assembled heads/intake/shaft rockers/ valve covers w/oilers....... $3700 to the door.
Old 12-09-2005, 03:27 PM
JUSTANOVA JUSTANOVA is offline
was that ebay stuff or do you have another source? Also can you run the sb2 stuff on a normal block or do you have to run the sb2 block too?
Old 12-09-2005, 04:00 PM
You can run it on a conventional block. EBay is a good source, but there are others also. Not as many as once before though. The stuff was dirt cheap and sold by the pallet for pennies at one time.
Racy's prices seem in line with what I have seen.
Old 12-09-2005, 04:11 PM
i got most of my used parts from evilbay, im an ebay whore.
