Old 02-25-2010, 04:56 AM
The company I want to go with has low profile acorn lug nuts to hold the adapters on to the hub or axle. I'll have ARP studs on the adapters and the hub and axle. The adapters are hub and wheel centric also. Like I said, I think I'll be fine. I just wanted other input as well.
Old 02-25-2010, 12:33 PM
deuce_454's Avatar
if you are using bolt on adapters you will definately be fine
Jake: Hit it.
Old 02-26-2010, 10:18 AM
Rod P's Avatar
Rod P Rod P is offline
the days of the old cracked adapters are long gone (for the most part) back in the 80's we ran alot of sand cast wheel spacers and adapters and they used to get stress cracks in them, the new stuff for the most part are all machined aluminum or steel
try EZ Accessory for the part you need
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 03-01-2010, 11:22 AM
Apogee Apogee is offline
In my experience, the issue with the thinner wheel adapters has to do with the amount of material that is remaining under the conical seat for the lug nut. All of the force from the lug nuts is trasmitted through that conical seat, so the thinner it is, the lower the factor of safety. Due to the relative thinness of the adapter, lug nut interference with the wheel is a possibility, so it's a matter of gaining enough room for the wheel to clear the inner set of lug nuts without sacrificing more material than necessary.
For comparison, a cast C6 5-spoke wheel has ~5/16" thickness as the lug nut seat since it's pocketed on the backside. The depth that the lug nut sits in the adapter will be determined by the diameter of the 60 degree countersink, however even the shortest lug nuts will still add 1/2" or more, so you'll typically need reliefs in the wheels to clear standard, short, bulge-nosed lug nuts with any adapter 7/8" thick or less.
Tobin
KORE3
www.kore3.com
