Old 03-15-2010, 10:21 AM
Daz's Avatar
Daz Daz is offline
I really appreciate the info ! I've seen whole units for $250-$400. My 67' will probably weigh somewhere around 3400-3600 or so and it won't be driven much. It will be more like a weekend fun to drive, occasional track day/drag car. I'll be stuffing a LQ9 w/ LS2 rods, Victor Jr Mani, 750 Holley, .600+ Cam, L92's and a t56 in it. So I'm looking at around 450-475 to the wheel and I heard those rear ends can handle up to 500whp. I just need to find someone to fab it in and then I'll be set.
I found a guy that can make a S/C T-Bird rearend/IRS fit in it but I'd like to stay with the GM as much as possible but if it come to it I'll thow a 8.8 on it !
Any info I get is deeply appreciated so you guys keep it coming, Thanks !
Old 03-19-2010, 08:43 AM
BMR Tech's Avatar
BMR Tech BMR Tech is offline
The rear will handle that power easily with a few mods, there are tons of GTO's running around with 450-475 to the wheels. The nice thing about the IRS from a fabricators point of view is that it only has 3 mounts, two front bushings and one on the diff cover, so physically mounting it is a breeze. What I am unsure of is just how much floorpan surgery will be required and if it will physically fit between the frame rails. If it fits within the frame rails and doesn't require frame rail modifications you could simply relieve the floorpan where it was necessary, fabricate cradle mounts off your existing frame rails, make upper shock and spring mounts (or even better, coil-overs), and have an IRS in your car!
The other good thing about these IRS rears is that they work. They really weight transfer well. We have seen 60 ft. times down in the 1.40's with just our polyurethane cradle mounting bushings and Drag Bags. If you want to see real world usage, check out our Project GTO. Some of the stuff is outdated now (this was back in 2005) but a lot of what we learned about the rear could be helpful in making your decision to go for it or pass. I have wanted to do this conversion for a while now, would love to see somebody actually do it!
Brett
WWW.BMRSUSPENSION.COM
Old 04-02-2010, 08:02 PM
Daz's Avatar
Daz Daz is offline
Thanks for the info ! Man I wish you guys were here in Cali cause I would let you guys handle it. I'm really liking this better then the C4 IRS. This way seems a lot easier and updated. Anymore info you have on this is deeply appreciated.
Old 08-11-2012, 09:55 AM
wgearhead67 wgearhead67 is offline
Default did it work?
DAZ (or anyone else), did u do this swap? I came across a great deal on a GTO IRS, and was thinking of swapping it into my 67 Camaro. My concern is track width. I think the GTO is wider and narrowing would be tough. So really interested to know if anyone else was successful with this swap. Thanks!
Old 08-14-2012, 07:43 AM
Daz's Avatar
Daz Daz is offline
Sorry man, I ended up selling my camaro ! It was just too much work for me, especailly on a budget(need some major welding) ! I now have a '74 Datsun 260z. Parts are much easier to find, and are cheaper, and I can find them in the junkyards. I've built a turbo 4.8 for it and I still need a t56.
Old 08-15-2012, 07:58 AM
Thanks for posting a reply Daz. Sorry to hear the Camaro is gone, but I certainly understand the cost limitations - constant struggle. Similarly, I am going to forego the IRS idea for now and focus money and time on other parts of the car. Your new project sounds like fun too. Too bad we aren't closer in location as I have a T56 I bought for my Camaro that I don't need any longer.
Old 08-15-2012, 10:06 AM
Daz's Avatar
Daz Daz is offline
How much did you want for it ? Where are you located ? Is it a LS1 or Lt1 t56 ?
