  #13
Old 03-16-2010, 11:34 PM
JRouche JRouche is offline
I think there IS some confusion in the thread.
Fittings as I see it are fittings for hard lines and couplers and adapters between the brake components and hard lines and hoses. NOT hose fittings. Most guys are not making their own brake hoses. So the fittings as far as that is concerned didnt fit in the thread. I dont think the OP was making his own brake hoses. I saw it as him looking for the fittings that are used in between the hoses and brake components and maybe making up his own hard lines. If so then all brake fittings from his list of manufactures are equal and interchangeable.
And as far as making up your own hoses for fuel, oil or air lines its a piece of cake. I have done a few hose ends. And you DO need to make sure you are using the correct hose end for the hose used. Teflon core hose will use a diff end than a rubber core hose.
For teflon core (braided stainless steel outer) I still like JIC fittings. And all of the manufactures that make hose ends for teflon core hose use steel ends, I think. And for fuel I only like the teflon core.
For rubber core hoses they will take an entirely different end. And they are usually in aluminum. I have used many manufactures hose ends for the rubber core hose and some are better than others. They all seem to hold to the dimensions for the rubber core and outer braided shield. But some of the manufactures of hose ends use a better method of securing the end to the hose IMO.
And if a guy were to make up his own hoses then I would recomend using the ends from the same supplier of the hose. I have so many manufactures of hose here that it took some time to find a "universal" end that I knew I could order and it would work. And they are really good, made in the US ends.
Now as far as making your own hoses with reusable hose ends I have tried it all. Went through alot of cuts to get it down to a science. I started with a cutoff saw, hand held at first. I was having problems with stray strands of SS wire. And once the wire starts to unravel its time to start over. And really, the type of tape you use makes a diff.
So what I do now is use 3M electrical tape and wrap a very tight wrap or two around the hose where I want to cut it. As tight as you can before breaking the tape. Thats why 3M tape works, it has a high stretch factor before it snaps. Then I put the hose in my home made 4" chop saw. It has a thin blade and spins fast. But the best thing about the chop saw is it supports the hose for the entire cut. No tapered cuts. I let the rubber core hose completely cool before removing the tape. I have removed the tape right after the cut and the rubber core was still warm and expanded. Pushing out the ends of the wire. Let it cool and when you remove the tape the end is still small and a lil tapered from the tight wrap of tape. Then the hose is ready for the end. I can usually get the nut on the hose without any loose wires. Screw the nut on. The type I use screws the nut on counterclockwise then the other part of the hose end with the nipple screws onto that nut in a clockwise direction.
I have made up alot of hoses for air and fluid with reusable hose ends doing this and so far so good..
Oh, but brake hoses are NOT supposed to use reusable hose ends. Crimp type only IMO. JR
