Old 02-23-2010, 11:48 AM
Daz's Avatar
Daz Daz is offline
Default 04/05 Gto Irs
Has anyone done a 04/05 GTO IRS on their Camaro ? I see them all the time on craigslist and was just wondering.
Old 02-23-2010, 02:06 PM
JKnight JKnight is offline
That particular IRS unit is not known for it's strength so I believe a lot of people avoid it for that reason. Most figure that if they're going to fab in an IRS unit, they might as well at least use a strong one.
Old 02-23-2010, 03:52 PM
Daz's Avatar
Daz Daz is offline
Thanks for the info ! I was going to use a C4 IRS but cannot find a someone to make a kit for me or one for under $1000.
Old 03-15-2010, 07:47 AM
BMR Tech's Avatar
BMR Tech BMR Tech is offline
The GTO IRS is a nice compact unit and you can get them ridiculously cheap but gear selection and posi options are limited and somewhat expensive. As for strength, they are not really too bad since the GTO came stock with a 400 horse LS2 and the car weighs 3750 lbs. We took our project car into the 10's with a stock IRS and our HD 300M CV shafts/stub axles. After a while we tore up the posi unit and went to an aftermarket differential. Keep in mind that our race weight was just shy of 4000 lbs. and we were drag racing it hard. If you put one in a 3400 lb. Camaro with a typical 450 horse motor, it would probably survive for a while. We sell a lot of the 300M stub axles and CV shafts for these cars and I believe there is a company offering a 8.8 Ford differential upgrade for them now that bolts in place of the stock diff. For the low prices I have seen on Ebay for these assemblies and the compact nature of the design it just might be a viable retrofit option. You could put it in there stock and upgrade down the road when it becomes necessary!
Brett
WWW.BMRSUSPENSION.COM
Old 03-15-2010, 09:21 AM
Daz's Avatar
Daz Daz is offline
I really appreciate the info ! I've seen whole units for $250-$400. My 67' will probably weigh somewhere around 3400-3600 or so and it won't be driven much. It will be more like a weekend fun to drive, occasional track day/drag car. I'll be stuffing a LQ9 w/ LS2 rods, Victor Jr Mani, 750 Holley, .600+ Cam, L92's and a t56 in it. So I'm looking at around 450-475 to the wheel and I heard those rear ends can handle up to 500whp. I just need to find someone to fab it in and then I'll be set.
I found a guy that can make a S/C T-Bird rearend/IRS fit in it but I'd like to stay with the GM as much as possible but if it come to it I'll thow a 8.8 on it !
Any info I get is deeply appreciated so you guys keep it coming, Thanks !
Old 03-19-2010, 07:43 AM
BMR Tech's Avatar
The rear will handle that power easily with a few mods, there are tons of GTO's running around with 450-475 to the wheels. The nice thing about the IRS from a fabricators point of view is that it only has 3 mounts, two front bushings and one on the diff cover, so physically mounting it is a breeze. What I am unsure of is just how much floorpan surgery will be required and if it will physically fit between the frame rails. If it fits within the frame rails and doesn't require frame rail modifications you could simply relieve the floorpan where it was necessary, fabricate cradle mounts off your existing frame rails, make upper shock and spring mounts (or even better, coil-overs), and have an IRS in your car!
The other good thing about these IRS rears is that they work. They really weight transfer well. We have seen 60 ft. times down in the 1.40's with just our polyurethane cradle mounting bushings and Drag Bags. If you want to see real world usage, check out our Project GTO. Some of the stuff is outdated now (this was back in 2005) but a lot of what we learned about the rear could be helpful in making your decision to go for it or pass. I have wanted to do this conversion for a while now, would love to see somebody actually do it!
Brett
Old 04-02-2010, 07:02 PM
Daz's Avatar
Daz Daz is offline
Thanks for the info ! Man I wish you guys were here in Cali cause I would let you guys handle it. I'm really liking this better then the C4 IRS. This way seems a lot easier and updated. Anymore info you have on this is deeply appreciated.
Old 08-11-2012, 08:55 AM
wgearhead67 wgearhead67 is offline
Default did it work?
DAZ (or anyone else), did u do this swap? I came across a great deal on a GTO IRS, and was thinking of swapping it into my 67 Camaro. My concern is track width. I think the GTO is wider and narrowing would be tough. So really interested to know if anyone else was successful with this swap. Thanks!
Old 08-14-2012, 06:43 AM
Daz's Avatar
Daz Daz is offline
Sorry man, I ended up selling my camaro ! It was just too much work for me, especailly on a budget(need some major welding) ! I now have a '74 Datsun 260z. Parts are much easier to find, and are cheaper, and I can find them in the junkyards. I've built a turbo 4.8 for it and I still need a t56.
Old 08-15-2012, 06:58 AM
Thanks for posting a reply Daz. Sorry to hear the Camaro is gone, but I certainly understand the cost limitations - constant struggle. Similarly, I am going to forego the IRS idea for now and focus money and time on other parts of the car. Your new project sounds like fun too. Too bad we aren't closer in location as I have a T56 I bought for my Camaro that I don't need any longer.
