Old 03-26-2010, 09:38 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
The Wilwood is a 570 degree dry boiling point.
Do you run an extra quart of oil in the crankcase - or is that to replinsh after running?
Pads???? I have GM delco Corvette pads in the C5 calipers and it is using slotted/drilled rotors.
On the subject of pads....what type would be better than the stock C5 pads that are good for street and track?????
Power Steering.....yes, I need to drain and fill that. The fluid in there now has been there for 5 years and 11K miles.
Okay...any examples of air ducts on 1st gen Camaros????
