Old 04-04-2010, 06:18 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
i was actually looking for a set of good used 4.8l pistons but havent found any good sources yet...
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 04-04-2010, 06:21 PM
70rs's Avatar
70rs 70rs is offline
I wonder if any of the national wrecking yards would sell you a set? Like LKQ?
They have a TON of 4.8 engines. Or a new set from Pace or one of the other dealers should be reasonable?
Eric
Old 04-04-2010, 06:22 PM
70TWO NOVA's Avatar
yeah, ill have to check into that
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 04-04-2010, 07:50 PM
Why not mill the heads more? Did you have them angled milled or flat milled?
You can deck the block but you need to be careful of the piston's location in the bore. I can't remember on the trucks but on the cars, the piston is already above the deck stock. So decking the block is not ideal compared to working the heads.
Old 04-07-2010, 12:52 PM
Ventoso Ventoso is offline
What are you doing for a cam, and where do you want your cranking psi to end up?
I wouldn't really get obsessive over having machine work done until you plan out where that's going, because static compression pretty much means dick all (flame suit on). The cam is where the action happens, and if you're going the custom route you have a WORLD of possibilities that are open to you in attempts to negate machine work. Evidence of this can be found in many cars landing around the 195psi mark (about the pump gas limit) on a myriad or static CR's. Conversely, the example that 70rs alluded to shows just the opposite -- I don't know the combo he's speaking of in detail, but I bet it utilizes an OTS cam and it's bleeding off a ton of psi.
Lots of variables to keep up on.
Old 04-07-2010, 01:16 PM
70TWO NOVA's Avatar
Im going to be using the 2002 and later LS6 cam. I want to be somewhere around 9.5-9.8:1 static CR, and i still want to be able to run on 87 octane pump gas.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 04-07-2010, 02:08 PM
70rs's Avatar
The cam they used is a Trick Flow Track Max , PN#TFS-30602002. Specs are
220/224(@0.050") and 0.575 " lift with a 112 LSA.
They also stated they were tuning for running on 91 octane. The comp ratio ended up "about"11.5:1.
the article is in the September '09 Camaro Performers magazine. Page 68.
This engine is going in Track Rat. Steve Rupp is building this '68 Camaro. He may be able to give more detailed info about the engine build.
Hope this helps a little.
Eric
Old 04-07-2010, 02:51 PM
70TWO NOVA's Avatar
yeah thats a little more cam than what im running, and more compression too. im hoping to get to 400 maybe with the combo im running
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
