Old 04-06-2010, 10:44 PM
phillym5 phillym5 is offline
Default Twisting studs on the street??
So i was taking off my rear wheels to clean them up from all the driving i've been doing in the Camaro the last few days.. and i had to find a SUPER thin wall socket to get it over the lugs.
Once i got the lugs off... I notice the studs were looking a bit...... crooked.
So i pulled the axle out... and all five of the studs were twisted.
Same on the other side as well. They are Strange grade 8, 1/2 inch studs.
I have been enjoying the fact that the car has been hooking up like crazy in 2nd and 3rd gear once the tires get warm. Actually i have been quite impressed. They are the Nitto NTO5's. 335/19's.
The car has been running 750-760 rwhp... so i would expect it to blow the tires off... but it pulls nice instead.
Anyone ever hear of this from a "street car"... it has yet to see a dragstrip... and has yet to be "hole shot'd".
I had to cut them off flush to the axle... then replaced them with some grade 9 studs. Please don't tell me i have to drill the axle and the wheels to put some bigger studs in there.....
Old 04-06-2010, 10:47 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Are you sure the studs were fully press into the axles when installed?
Old 04-06-2010, 10:50 PM
YEah... they were threaded in.
Old 04-06-2010, 10:52 PM
98ssnova's Avatar
I wonder with the torque it has elongated the holes have you taken one out to inspect the flange?
Old 04-06-2010, 10:55 PM
Yes... i already have installed the higher grade bolts. Everything seemed good. The threads weren't damaged at all... and the new studs had no "slack" while putting them in. However... the old studs could not be threaded out. They had to be cut flush.. then backed out. I have a photo at the shop.. I'll post it in the morning.
Old 04-06-2010, 11:01 PM
98ssnova's Avatar
These were just installed then I will wait until i see your pic to see what you have going on. It seems like those could be the only two things that could be wrong? But i could be wrong..
