Old 04-11-2010, 01:46 PM
If I'd have checked before posting -- I would have led you right here!
http://www.purechoicemotorsports.com...rod/prd192.htm
Old 04-11-2010, 06:16 PM
Sti_Guy's Avatar
Sti_Guy Sti_Guy is offline
Another great place to get stuff is http://www.anplumbing.com/shop/
Great group of guys.
Old 04-11-2010, 08:43 PM
Greg, it's a factory GM steering box. The ratio is quick since the car is a WS6 model but aside from that, it's the typical steering box that GM used for decades.
Also, to be clear and I think you guys understood me, I need to make a hard bend right out of the steering box. That's what I meant by 90* inverted flare.
Anyway, would a banjo fitting flow enough fluid for the system to work? I didn't think they could flow enough fluid. After all, the lines at 3/8" feed and return. Banjos would look sweet and I can clock them anyway I want. They also have SAE or AN fitting ends. I have the mastercool flaring kit and I can do AN and JIC so no worries on hooking up to the banjos if they flowed enough.
Thanks guys.
Old 04-11-2010, 11:23 PM
Trey - check out that site I linked up - Pure Choice Motorsports - they have a section on steering fittings - pump and or boxes - and they have banjos and other fittings for them.
As far as the flow goes - I would think this is not an issue if they're selling fittings for this purpose...?
Old 04-12-2010, 06:30 AM
I did check them out and I'd hope they wouldn't be selling them if they couldn't flow well enough. I'd rather know instead of trust. It's the engineer in me. I like knowing how something works not just what works. Do you know who sells their stuff so I can look up a price? It appears they only sell through dealers and I only saw three listed on their page. Thanks Greg
My local NAPA place shouldn't have let the guy I talked to answer the phone. He had no clue about hard line fittings. That's not a problem honestly. I don't expect everyone at a business to know how to do everything in the business. However, he talked to me as if I was a dumbass and didn't know what I was talking about while I was holding the parts in my hands. That just ticks me off. So no business for them.
I've got a couple other hydraulic places around me that I could check into. I'm just really busy trying to finish school and take care of my job interview that I don't have time to see them during business hours. I'd rather research the issues first on my own.
Thanks guys
Old 04-12-2010, 04:40 PM
wedged wedged is offline
I know that feeling. Went into a (insert BIG hydraulic manufacturer name) shop near me and asked for copper or aluminum crush washers for a 10mm fuel pump fitting only to be told the fitting I had in my hand was 1/8" NPT. It was clearly not tapered. The pitch did not match pipe thread. It fit perfectly into the 10mm straight threaded electric walbro pump I was installing. I finally gave up trying to convince the person helping me that I knew what I had and left. They had 3/8 washers that were OK in diameter, but too thin. It was the manager was helping me.
