Old 04-14-2010, 01:24 PM
scherp69's Avatar
scherp69 scherp69 is offline
Thanks JR. I'm not sure if I've painted a clear picture though of what my plans are. None of the exhaust tube that I plan on welding will actually be welded directly to the tank itself. Here's what my plans are:
- I've welded in a filler panel from a camaro between the tails lights, so now it's like the camaro set up.
- I'm using the Ridetech filler cap and filler neck.
- On the inside of the trunk, I want to weld in a piece of exhaust tubing that will go from the inside of the trunk to under the car
- The ridetech filler neck will connect to exhaust tube with rubber hose
- The filler neck that is connected to the gas tank will connect to the exhaust tube under the car with rubber hose
- So basically I'm just using the exhaust tube in the middle to connect to the filler cap tube and the gas tank filler tube
- I only plan on welding the outside around the exhaust tube where it goes through the trunk floor and out the bottom of the car
Hope this paints a better picture of what I'm doing. I only plan on using maybe 12 to 18" of exhaust tube. As for any gas fumes.....I don't even have the tank yet to consider putting fuel in it.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
