Old 04-15-2010, 09:58 AM
buickfunnycar.com's Avatar
Originally Posted by The WidowMaker View Post
damn im strong...... maybe i'll dig mine out tomorrow and see, unless someone else has a number. my guess is somewhere in the 85-100lb range. my wife helped me put it on last time, and theres no way shes lifting more than 50 lbs as easy as she did. but then again, maybe.
Gotta be more than 100#'s,I've been wrestling with mine for awhile...
www.buickfunnycar.com
Old 04-15-2010, 08:27 PM
70chevelle406 70chevelle406 is offline
Default 70
Originally Posted by brans72 View Post
Thanks Tyler! I called you couple weeks ago asking about it and for sure I do need a hood after see what was under the paint. I can not wait to see the pictures.
Yea me either. I am still in need of some lower torsion hood springs as well. Also not sure if the stock torsion bars for the trunk will be ok to use with the carbon deck lid.
Vince
Old 04-15-2010, 08:42 PM
The WidowMaker's Avatar
i shot all of my sample colors today, so i had to dig the hood out anyways. drum roll............ 75lbs. now i had to sort of balance it on the scale since my 225+ the hood exceeded the scales limit, but i did it more than once and that should be pretty damn close.
there was a thread on the camaro forum about a guy that used shocks and got rid of his trunk torsion springs. he was then able to pop the trunk and have it open under some control, instead of flying open as it does in stock form. all that was required was the weight of our deck lid and the formula did the rest. i eventually will get there.......
"The WidowMaker"
Old 04-16-2010, 12:15 PM
75lbs. WOW! I wonder what the weight of the carbon hood will be? That shock seems like a trick idea. We'll see what I plan on doing when the parts come in.
Old 04-16-2010, 12:54 PM
Man...I woulda swore it was over 100#'s.
My guess on the c/f part is 24-28#'s.
Old 04-16-2010, 03:27 PM
brans72 brans72 is offline
I say we gang up and get a group purchase on a batch of Carbon Fiber Chevelle hoods from Anvil! So who is coming with me
Old 04-16-2010, 05:35 PM
im in, but probably for a carbon/glass hood since it will be fully painted anyways. lets see what happens.
"The WidowMaker"
Old 04-16-2010, 05:41 PM
That is 2 for the carbon/glass hoods now! Let's keep it going
Old 04-17-2010, 01:03 PM
Anvil is tooling off of my hood, deck lid, and a-pillars, so technically I will be getting them in trade. So count me out, otherwise i'd definitely be in.
Vince
Old 04-17-2010, 05:20 PM
You better hope your parts are 110% straight buddy or the lench mob will be coming after you just Joking. So your gonna give us spy photos huh
