Old 04-24-2010, 04:45 PM
QUIKRNU QUIKRNU is offline
Default 1969 Camaro Fuel Tank options
I am building a 1969 camaro that will be mini tubbed. I want to build it using all factory or close to oem as possible. Its a ls7 with a cam swap makes about 625hp and 605tq I want to put Nos on it for another 175hp. I got the factory dry sump mounted between the rad and the factory spot for the battery. The oem tank with the fuel injection pump in tank wont work because of the mini tubbs. Will a factory corvette z-06 fit in and work or what other Ideas are out there?? Or is there anyone out there that builds a oem style tank for a mini tubbed car?? thanks
Old 04-24-2010, 06:52 PM
We have Ricks Hot Rods Tanks made in stainless steel with internal fuel pump, hang in the factory location and use the factory filler arrangment.
Frank Serafine
Old 04-25-2010, 11:27 AM
Thanks for the info..what kind of prices...I have worked very hard to keep it like factory options and I want to keep it as if gm did it if that means modifing a new plastic tank so be it...but I want to keep it simple..to so...if I am going to get a stainless tank I dont want to be painting black or something so it looks factoryish Plus I live one mile off a gravel road. SO any one else with suggestions and what are the prices thanks..
Old 04-25-2010, 12:43 PM
Are you running a wet shot of NOS or dry shot?
Frank Serafine
Old 04-25-2010, 04:25 PM
wet NOS... and I want this to be reasonable in cost cause by the time it gets to Canada and all the taxes and shipping its a little bit ridiculous.
Old 04-25-2010, 05:11 PM
As long as your adding nitrous and dedicated NOS fuel from another pump. You can get by with a in tank Walbro pump. $1100 for the tank, sender and pump, mounting straps, shipped in the lower 48.
Frank Serafine
Old 04-25-2010, 06:18 PM
So another pump which costs?? I do perfer something from a gm type car or whatever so it would look like gm thought this car up...but thank you for the info and I will keep this in mind I have a month and a half to get her on the road...
Old 04-25-2010, 07:27 PM
You said you were running a wet shot which would mean a dedicated nOS fuel system. A dry shot would relie on the injectors to ramp up for the nitrous, which would toss you into a bigger pump class.
I do not think you will find a factory pump capable of handling all you have one one pump.
Frank Serafine
Old 04-26-2010, 08:46 AM
I am fairly new to this hot rod things what I been suggested was wet whats better wet or dry???
