Old 04-29-2010, 08:56 PM
ccracin's Avatar
ccracin ccracin is offline
Thanks guys. I have been playing around with it. I think the trouble I have is that I am thinking the base steel sheet metal should melt as with a typical weld. I don't think that can happen here. This is almost brazing using a mig to short circuit and feed the wire. I have had decent luck with half the voltage and twice the wire speed that I would use to weld with carbon steel wire. Any other input would be great. I wish I had the coin for a TIG! Oh, well learn by doing!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 04-29-2010, 09:01 PM
Chad! Post up a picture or your bird poop!
Old 04-29-2010, 09:05 PM
ccracin's Avatar
If you don't have anything nice to say!!!!!!!!!!! Actually, how did you know? I had some pretty nice goobers at first. I'm getting there. We'll see if where I get to is where I want to go.
Don't tell me you don't have anything to say on the subject! I really think there is hope for this. Pick up a spool and head to the "Shed" it's R&D time!
Chad
Instagram - @cctek
Old 04-29-2010, 09:13 PM
I've never even TIG'd with the stuff...
I had to go research to see if you were out of your mind when you said you were MIG'n with it!
My first question would be -- if it's more like "brazing" -- about it's strength and cracking etc.
Old 04-29-2010, 09:21 PM
ccracin's Avatar
I am definitely out of my mind, but that is for a different thread. Here is what got me started. This is by Ron Covell.
http://metalshapers.org/101/covell/c...ilbronze.shtml
It absolutely does not have the strength that carbon steel does. As with all things, I believe in the correct application it would have some advantages. I would not use it on anything structural. But, for some body mods I think it would do a nice job. IE. Filling door handles holes, parking light holes, smoothing firewall, etc. I also read that body shops are moving this direction when welding high boron sheet metals. This material is heat treated and supposedly using the silicon bronze reduces the heat input and does not affect the material properties as much as carbon steel filler. I'll get some pictures shortly of what I am doing.
Chad
Instagram - @cctek
Old 05-19-2011, 04:48 AM
tom091074 tom091074 is offline
Here is a site I found that might help. I have not tried it yet but I'm looking forward to the challege. Good luck.
http://www.mig-welding.co.uk/brazing.htm
Old 05-19-2011, 08:01 AM
If my welding looked like that -- I'd switch to glue.
