Old 05-09-2010, 06:49 PM
kochevy67's Avatar
kochevy67 kochevy67 is offline
I called him and he is going to get back to me on a few other ?'s I had. I also thought it wouldn't fire the injectors but I am not sure so I thought I would ask.
Old 05-09-2010, 07:13 PM
TurboNova's Avatar
TurboNova TurboNova is offline
It stops the ground pulse from the ECU to the injector.
Brian Macy
Instructor
EFI University
www.efi101.com
owner
Horsepower Connection.com
Fuel Injection Dyno Tuning Turbocharging
cell 360-280-6112
Old 05-09-2010, 08:41 PM
kochevy67's Avatar
I thought it killed the fuel also, but the stock harness has the injectors and the coils on the same plug. Is it possible to that it could be killing the spark? I am going to have the ECM reflashed and hope for the best.
Old 05-10-2010, 05:14 AM
RSZ28 RSZ28 is offline
It depends whose VATS patch is being used and which LS2 controller (E40 or E38) and which base factory tune is in there. There are typically 3 and at least 2 of them are different in method. (HPT-EFilive-LS2edit).
VATS overall is a series of steps that prevent starting and each package generally takes a different route. The coils may turn on and injectors may be left off or cycled once with a fire and cut depending on which VATS patch and whether other tests need to be satisfied. Only way to really tell whether something is missing is with a scanner.
Old 05-10-2010, 06:15 AM
kochevy67's Avatar
The snapon scanner shows what codes are being thrown out but does not show what the vats is doing ie: killing spark or killing fuel. I am going to have the ecm reflashed and go from there unless somebody has any other advice.
Old 05-10-2010, 12:30 PM
TurboNova's Avatar
It stops the ground pulse to the injector.... they do not fire... even though they have 12v power to the other side of them.
Brian Macy
Instructor
EFI University
www.efi101.com
owner
cell 360-280-6112
Old 05-10-2010, 05:12 PM
kochevy67's Avatar
So is the spark killed as well?
