Old 05-22-2010, 06:50 PM
Karl Buchka Karl Buchka is offline
*Insert obligatory nut joke here*
Missing the centering ring underneath the nut, should end up looking something like this when it's all stacked on there.
Large nuts or small hands? You be the judge.
'82 Volvo
Old 05-28-2010, 07:17 AM
Started on the front uprights:
Should look something like this when they're done:
CTS-V/C5 Corvette hubs bolt in to the center hole. Camber adjustment is done by swapping the rectangular shims up top.
'82 Volvo
Old 05-28-2010, 07:31 AM
HWY Nova HWY Nova is offline
Can't wait to see the uprights welded up and installed!
--Eric
ET
62 Nova Coupe
62 Nova Convertible @ Ironworks Speed & Kustom
Old 05-28-2010, 12:31 PM
--Eric
Thanks! The install is right around the corner. We just need to finish fabricating... everything.
'82 Volvo
Old 05-28-2010, 12:35 PM
deuce_454's Avatar
unless you hard anodize the centerbolt adapters and nuts i would be worried about gouging... the thread should in to teh best of my knowledge be made in steel so the aluminum dont fuse then you try and loosen/tighten it..
I have an alfa corse spindle from a 93 DTM alfa and its made in thinwalled steel for teh same reason i suspect...
Jake: Hit it.
Old 05-28-2010, 04:33 PM
Not to worry. The adapters and nuts will be Type III anodized and the machining clearances reflect that.
'82 Volvo
Old 05-28-2010, 04:57 PM
nvr2fst nvr2fst is offline
You guys definitely know how to design/machine some sweet parts. Its going to be heck of a Volvo.
Old 05-31-2010, 07:34 AM
Thanks!
All four adapters are finished. Alex really did a great job on them.
Got the centering rings back from anodizing:
All bolted up:
Final weight:
Progress on the front uprights:
'82 Volvo
Old 05-31-2010, 10:38 AM
MSTSFabbed MSTSFabbed is offline
Amazing. Those look great! Looks like tigging in those cross peices on the uprights is gonna suck haha.
Stephen S.
Old 05-31-2010, 11:40 PM
frojoe's Avatar
frojoe frojoe is offline
This fabrication work is awesome, good job on not only the research & modeling, but carrying through with it too.
And hip hip hooray for Solidworks, anything you can dream up can be a reality when solid modeling!!
Joe
1972 Nova with twin 6466's and T56 Magnum in the works. Speedtech, Ridetech, Wilwoods etc. Swap thread --> http://ls1tech.com/forums/showthread.php?t=980909
