Old 12-28-2005, 12:33 PM
XTRMEASURES's Avatar
XTRMEASURES XTRMEASURES is offline
Default lt1 heads on old 350
i have an old 350 4bolt block that i plan on building this summer.
now a buddy has an lt1 engine at my shop and we were talking about maybe useing the heads and Intake manifold.
the thing i want to do is make it a fuel injection style engine, so he's goin to sell me the parts i need if it can be done.
jamie
Old 12-28-2005, 01:02 PM
camcojb camcojb is online now
It would require a LOT of work to get them on there. The water jackets are completely different so they'd have to be welded up and re-machined. Much less expensive to go a different direction.
Old 12-28-2005, 01:03 PM
thanks that what i needed to know
Old 12-28-2005, 01:39 PM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
Will the LT1 intake will bolt to conventional SB heads?
Old 12-28-2005, 02:50 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
they will bolt up if you modify the bolt holes on the intake
But also remember that the intake is a dry intake so coolant doesn't flow through it so you have to re-route coolant.
Also the LT1 heads are reverse flow heads.
