Old 05-24-2010, 06:43 AM
That is the weirdest engine damage I've ever seen.... it almost appears that the PISTON was revolving in the bore and getting smacked by the valves... and we know that just didn't happen... because there is nothing that would rotate the piston. Unless the rod somehow is "loose/broken" and hanging down just enough to get touched by the crank and that somehow rotated it... But that doesn't sound plausible either, since that would really have to major interference in the crankcase. Now I'm just dying to see the bottom-end.
Old 06-13-2010, 03:00 AM
OZ Duster OZ Duster is offline
Default Boot Trim
Have decided to do some work with the boot. Removed the Sub box after disconneting the amp and cables.
The boot goes a fair way back under the rear parcel shelf so I am thinking of using the space for storage, jack, tools etc.
Mocked up a false floor and worked out what angles to use. Still striking some problems with the fuel tank filler tube. Need to work out if the side panels are going to be vertical or slope in toward the wheel recess.
This is close to what I have in mind,
Other than using the sides of the boot for storage (limited in size) I also like the idea of the exposed spare wheel. I still need some room for a smaller single sub box as the twin 10" subs will get the flick. Any suggestions welcome.
Old 06-13-2010, 06:52 PM
4thechallenge 4thechallenge is offline
I'm very impressed... I'm glad to see another mopar!
Great color combo and awsome look
Old 06-14-2010, 01:49 AM
Default Boot Trim - Part 1
Completed the first stage of the boot fit out.
Measured up and cut the main part of the floor in 10mm MDF and the outer sections in some left over particle board used on door trims.
Cut out the recess for the wheel. Measured five times cut once. Then measured up the carpet and carefully cut around the perimeter and then the fuel filler tube. I left a little bit of carpet overhanging the wheel recess for a tight fit. Wheel went in nice and snug.
The Sub box was refitted and the dodgy wiring fixed up to avoid a fire. :raisedeye
That will do for now (nothing like being stooped over for a couple of hours to stuff your back). Next stage will be the side panels and mounting points for a few tools and cleaning gear.
Old 06-14-2010, 11:36 AM
rjsjea's Avatar
rjsjea rjsjea is offline
The spare looks pretty good in that trunk..
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 08-03-2010, 03:21 AM
Default Engine Number 2 ?????
Pulled the Duster out of the shed two days ago and noticed a knocking noise as the engine came down to idle. At first thought it was something rattling loose but now seem to think it is coming from inside the block. Off idle and with a few revs it goes away but returns as the RPM drops down to idle. It is not a set rythym but it definately gives me that sinking feeling. All the fluids are fine its not overheating and gave no indication of power loss on the run out to willowbank the other sunday. Hope im not up for a rebuild......
Am i missing something obvious or is it a big end bearing like im thinking?
Old 08-04-2010, 01:38 PM
Moabdude's Avatar
Moabdude Moabdude is offline
Nice
I love the Duster.
What brand/model wheels are those?
>68 Camaro pro touring, 400SBC, 18" Intro's, T4 13" Baer Eradispeed, Airride, Speedtech, Autometer, König seats, March, Magnaflow. Hope to finish in 2006...2007...2008…2009...2010...2011...Yes, 2012 and its finished (well, will it ever be finished )
>69 Nova project, LS1/4L60e, Corvette C5 calipers+rotors, AFX spindles, 69 Camaro body mods, Just got it painted.
Old 08-05-2010, 03:25 AM
Originally Posted by Moabdude View Post
Nice
I love the Duster.
American Racing Torqlites, 18x8 and 17x7
Old 08-11-2010, 01:44 PM
Bryce Bryce is offline
welcome, nice falcon!
Old 08-11-2010, 06:51 PM
chevmech1969's Avatar
chevmech1969 chevmech1969 is offline
Welcome, Nice Duster
Johnson's Rod'Z
A man with few vices, has damn few virtues.-Benjamin Franklin
