Old 06-20-2010, 11:33 AM
DOOM's Avatar
DOOM DOOM is offline
Default Roof Question
Hey guy's ..... I was just chopping away at the Camaro today ,removing the roof . What holds the roof to the drip rail
Mario
USCOLLISION
Old 06-20-2010, 12:44 PM
dhutton dhutton is offline
About 1000 spot welds. I found the easiest way to remove it was to grind through the spot welds with a cutting disc.
Old 06-20-2010, 05:51 PM
greycamaro greycamaro is offline
doing the same at the moment doom. please let me know how that works out.
alex
Old 06-20-2010, 07:23 PM
Autokraft's Avatar
Autokraft Autokraft is offline
Supporting Vendor
Autokraft.org
Mario, like Don said alot of spotwelds along the driprail, grind off with a die grinder.Just try to be careful u dont grind through the driprail
Autokraft
Old 06-21-2010, 03:57 AM
redfire69's Avatar
Yep, this is one spot where more rust helps out. My drip rails were shot so off they went too. It's easier to cut the roof off an inch or so back, then you can find and dispense with the spot welds. Good luck!
Ron
69 Camaro Redfire
Old 06-21-2010, 05:39 AM
DOOM's Avatar
Thanx Guy's!! I'll get to grinding..
Mario
USCOLLISION
Old 06-21-2010, 07:29 AM
Bow Tie 67's Avatar
Bow Tie 67 Bow Tie 67 is offline
It's like they used some type of rolling spot welder. Grind through most of each spot weld and then peel off the edge of the roof. It helps if you cut the roof as close to the drip rail as possible. Tedious but not hard.
Matt
Project: " Chain Reaction "
A.K.A. " BIG " by wife, biatch in garage.
1969 RS Camaro, L92 T56, Chassisworks sub, Quadra-Link, Bear, Ford 9".
