Old 06-28-2010, 04:05 AM
Headlines's Avatar
Headlines Headlines is offline
Default New guy - Dumb questions
Attention all GURUS
After attending the MotorState Challange and gettting a bit of the bug I have a question
Automatic versus Standard
I know what you get with a standard set up but is there any good or bad reasons for an automatic set up if you are Going to road course or Auto course the car?
Stay tuned there are many more stupid questions coming
www.headlinesdirect.com
Old 06-30-2010, 10:31 AM
Headlines's Avatar
No one ??? Bueler??? Bueler???
Old 06-30-2010, 11:22 PM
deuce_454's Avatar
first of all... your question is a bit broard to say the least.. and to answer your question
Q: "is there any good or bad reasons for an automatic set up if you are Going to road course or Auto course the car"
A: Sure.. lots!
any choice when building a car is bound to be a compromise... and if you install a well built automatic with a paddleshifter and a well engineered converter its not a bad choice for a car that see the track from time to time...
but it will rob more power than a straight cut manual tranny.. and the weight of the converter will hurt your acceleration out of the slow corners becaose of the bigger polar moment of inertia..
on the other hand, a straight cut, manual tranny will suck in daily driving..
and remember, "there are no stupid questions, only inquisitive idiots"
(im only kidding) but seriously, do a search and read alittle before posting questions, noone here will mind spending half an hour helping you, bit it will have to be with a question you need answered because you are about to buy somthing or cut up your car, not just questions like "whats better turbos or blowers" or chevy vs ford
wellcome btw
Jake: Hit it.
Old 06-30-2010, 11:25 PM
You looking for a Sunday cruise or to compete?
Old 07-01-2010, 03:53 AM
Headlines's Avatar
The car could be a bit of a cruiser we would like to run the beach on the weekend, and maybe a few regular car events but mostly a competition car is what I am thinking
The question was meant to be broad to get the widest realm of opinion on the subject
If there is a thread you think I should read please point me in the correct direction
I know there is a trade off in weight and acceleration
I prefer a standard transmission and don't mind it as a daily driver (our vette is a 6 speed)
Is a paddle shifter a must in an auto cross situation if you are not running a conventional stick??
does anyone run an automatic transmission in the road courses or the autocrosses ?
Is 6 speed the way to go or is there an argument for 4 or 5 speed ?
Old 07-03-2010, 07:44 AM
deuce_454's Avatar
the paddleshifter is a must in my oppinion if you are running an automatic transmission on a road course or autocross...
a manual tranny works great with a stick.... especially for shorter races, for endurance races the paddles will help alittle, but thats a whole different ball game..
and weather you need a 6 speed depends on the track, your car, the engine.. the audis that won lemans all run 3 speed manual transmissions but thats a light car with broad powerband and emphasis on low weight and high durability.. and they dont have standing starts....
a heavier car with narrower powerband needs more gears.. but again depending on the track,
but you most likely wont really need more than a 4 speed if your aim is roadcourse or auto x... on the street though its nice with the double overdrive OF A T56.
an all aluminum 358 sb2 engine with a jerico 4 speed will propably be the optimum for road course car... but it will suck on the street... for a street car that sees some track use id say an ls7 with a 6 speed was the best compromise
Jake: Hit it.
Old 10-21-2010, 08:07 AM
sevillaz28's Avatar
sevillaz28 sevillaz28 is offline
Its kind of up to you on where you want your car to be set at. How much time are you really going to spend on the track or at an Auto-x event? Is your car more for fun? 4 speeds are great and so are 6 speeds but then you need to think about gears and wheel size and weight and make it all work for you.
I currently have my original 396, th400 and 12 bolt in my car and it kicks butt on the street and at the track. I just need to do one more gear change and one more suspension mod and I think I can start knocking off some time on the road corse.
Forgot to mention, I have done a ton of work to my car. 625hp and 588lbtq helps out a lot, not to mention all of the suspension work
Old 10-21-2010, 12:42 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Seems to me that the cars built mainly for track use all have a 5 or 6 speed. Perhaps reading some of the threads on cars like One Lap or Bad Penny would give you a better idea of what you would need to do.
Curtis
Old 10-21-2010, 01:32 PM
Ron in SoCal's Avatar
So true in our world.
F1 uses paddles...if only we could rev our motors that fast!
Ron in SoCal
69 Camaro in progress
