Old 07-04-2010, 10:02 AM
David Pozzi's Avatar
Compare duty cycle, when you get on a big job on thick metal where you really turn the welder up and weld a longer time, the smaller welder will turn off when it get's hot. Duty cycle is the number of minutes you can weld out of every 10 minutes. A 5 min duty cycle is 50% duty cycle.
98% of the time you won't need many amps to do the job, but if I could upsize for only $100 or so. I'd do it.
David
http://www.PozziRacing.com
Old 04-30-2011, 12:55 PM
johnnymac46's Avatar
johnnymac46 johnnymac46 is offline
I know im a little late but thanks for the help deciding on a welder i went with the 211 MVP it works awesome.
The auto darkening helmet was a great investment as well. I would highly recommend getting one to any one who welds.
Old 04-30-2011, 01:08 PM
Nice!
Personally -- I HATE my Miller Elite helmet. I'm older... as in DIRT OLD... and many times (light gauges etc) it just won't be light enough for me.
I almost always use my OPTREL or my Speedglass.... they'll adjust to "5".
Just tossing that in if you find you can't see well... and seeing is EVERYTHING in welding.
Old 04-30-2011, 05:50 PM
I haven't had any problems seeing yet, but then again I'm still 23.
However I do have problems with my hearing already thanks to four years of carrying a machine gun and explosions(training only not war symptoms dont want to give the wrong impression) so I use these little guys at work and on my car they are awesome ( http://www.amazon.com/Howard-Leight-.../dp/B001T7QJ9O ). They are battery operated to cancel loud noises (wives) but can be adjusted to hear ambient noise, and they are MP3 compatable.
Just another piece of gear I thought some people might like
Old 04-30-2011, 05:57 PM
Yeah --- that hearing can be an issue..... lets see... I've played the drums (still do) for 50 years -- and I'm an internationally licensed pyrotech... HUH? What'd you say?
Old 04-30-2011, 09:10 PM
Well played....
Old 05-03-2011, 05:19 AM
Mr. Weld you appear to ne very knowledgable about metal work do you have any bias on plasma cutters?
I'm already looking one bigger than I think I'll need but I dont see a reason to be able to cut something I cant weld I was thinking Miller again one of these:
http://www.millerwelds.com/products/...p?model=M13811
http://www.millerwelds.com/products/...p?model=M00243
My welder is rated to 3/8 and I really dont see myself doing anything bigger.
