Old 07-14-2010, 04:41 PM
awesometool's Avatar
awesometool awesometool is offline
thanks I try that first.
Old 07-14-2010, 04:51 PM
Todd thank for the help that did it
Old 07-14-2010, 04:55 PM
Great, I'm assuming you're running a relay?
Old 07-14-2010, 05:44 PM
Yes there is a relay. I had run the pump ground to a grounding block used for the amps. I moved the ground direct to the battery and its perfect. The grounding block has 2 gauge to the - side of the battery but a lot of radio grounds run off it. thanks again.
