Old 06-08-2010, 07:42 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Originally Posted by Rybar View Post
Nice job so far, I also like the color.
I agree with Ryan here.
GOOD JOB!
Old 06-09-2010, 01:44 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Here is one in the paint booth (garage)
After assembly
Here is the Second Skin Firewall I put on the bottom, tried spraying it but brushin it on worked better for me
Old 06-11-2010, 11:32 PM
ErikLS2's Avatar
Finally got my wheels on, Rushforth Super Spoke smoked titanium with brushed outers from Frank at Prodigy. The stance obviously needs some attention.
Would like comments on how the red calipers look with the rest. Personally I was unsure before I put it together but I think I like it.
Old 06-12-2010, 01:15 AM
deuce_454's Avatar
im also unsure of the calipers.... They look great, but also alittle "ricer" perhaps its just that the only two things on that pic is alot of blis (on a great looking car btw) and the red calipers...
get the stance right and finish the car before casting final judgement..
Jake: Hit it.
Old 06-12-2010, 10:00 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
I think it looks ok the way it is. It definitely stands out though, and you need to decide if that's what you like. I will warn you, having them powdercoated will get pricey since you have to pull the calipers completely apart and will likely need a rebuild kit since it's impossible to pull them cleanly without damaging the seals or pistons.
Matt
Old 06-13-2010, 04:21 PM
fvike's Avatar
fvike fvike is offline
I just read the title of the tread, then I remembered a Bob Dylan Lyric and googled it:
... see the rich man without any name.
Jokerman dance to the nightingale tune...
Your car should be named Jokerman.
1969 Ford Mustang - Build progress - My FQuick site
Old 07-18-2010, 04:23 PM
ErikLS2's Avatar
This is over on the A/C forum too but here's my latest project.
I wasn't to impressed with the brackets that came with my Vintage Air kit. I couldn't use it anyway seeing as how my firewall is already painted plus I didn't want any hardware showing on the firewall side.
Made this out of 1/2" tubing. I bolt in the upper bracket first, then attached the bottom half of the bracket to the evaporator case and install them assembled. I used Nutserts in the sheet metal of the car. The bottom of the bracket attaches to the little shelf there at the top of the toe board. You can see the Nutserts from the engine compartment but it's much better than right through the firewall. The little brace I made for the center dash support really firmed things up too
It is very sturdy and I probably could have done without that triangulated piece on the upper bracket but it really made the mounting much firmer and it gives me something to attach wiring harnesses and other stuff to later on.
Old 07-18-2010, 05:33 PM
The car looks great, I like the color. Nice work on the bracket.
Old 07-18-2010, 07:22 PM
awr68's Avatar
awr68 awr68 is offline
Nice progress! Looks good!!
Tony
'68 Camaro
Old 07-20-2010, 05:37 AM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
The blue and red combo looks fine....
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
