Old 08-09-2010, 12:06 PM
g356gear's Avatar
g356gear g356gear is offline
Default Subframe options for stock sub aftermarket parts?
I was talking to DSE about a new sub, but I would not be able to use my Speedtech A-arms, hotchkis sway, and Willwood brakes and spindles. Are there any other options for subs out there that I could swap my parts onto and still fit a wider front tire? Thanks.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 08-09-2010, 12:14 PM
Speedtech is the perfect solution for you. And since your both in Canada.........
Frank Serafine
Old 08-09-2010, 02:21 PM
Blake Foster's Avatar
the Speedtech frame will work.
have to upgrade to rack and pinion, and steering shaft kit and coil over shocks. maybe headers and away you go.
Blake Foster
www.speedtechperformance.com
Old 08-09-2010, 05:21 PM
g356gear's Avatar
I am running a BBC with some 2.25" Lemons race headers with my stock sub. Any issues with those on a Speedtech sub?
Old 08-09-2010, 05:53 PM
My GUESS is the header would clear, but I would not promise. I am sure Speedtech won't know for sure either. You may have to modify a tube or towo on the driver side.
Sounds like a winter project
Frank Serafine
Old 08-09-2010, 06:21 PM
coolwelder62's Avatar
Have you thought about reworking your stock sub.With a little bit of work you can fit a 9.5 wheel up frt.
Old 08-09-2010, 09:21 PM
LS1NOVA LS1NOVA is offline
What kind of work does that include?
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 08-10-2010, 07:47 AM
If you use a unisteer rack & pinion you can notch the outside parts of the sub frame by a few inches on each side.We found our unisteer rack on ebay under a company called fatrodder.about $595.00 plus shipping.
Old 08-13-2010, 02:24 AM
Roadrage David Roadrage David is offline
Its about time these ""afthermarket"" companys, wil divelop stuff for the pontiac engine mill insted of ""ALWAYS"" think on chevy engine blocks only. Pontiac hase a there factory block , but also 4 ""afthermarked"" blocks and more then 10 diferend aluminum heads to choose from!!.
A serius wake up call is called for , There is also no rack and pinion for pontiac powers cars, yet there are plenty brands making them for chevy!! shearing that marked.
One of these companys should step up!!.. funny thing is speed tech is advertizing a afthermarked ""firebird and transam subframe"", yet it sais no modifications hase been done to ecsept the pontiac engine. how lame is that!!!!!
Old 08-15-2010, 11:29 AM
jdeliveryguy jdeliveryguy is offline
Any pics of a notched subframe?
