Old 08-11-2010, 06:26 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
DEX III is whats suposed to be in it. and depending on the year if you still have paper blocker rings you can't even run synthetic fluid in it.
so yes 40 miles with the wrong fluid sounds about right. change the fluid then drive it for a few miles and then change it again. aslong as nothing is messed up internally you should be ok.
Old 08-12-2010, 08:20 PM
1HTBRRD's Avatar
1HTBRRD 1HTBRRD is offline
The transmission is from a 96 and I believe it had a factory looking yellow sticker near the fill hole that said DEXMERC....maybe it said DEX III, I will crawl under there and double check.
1962 Nova, LS1/ T56, DSE Mini tubs and subframe connectors, Church Boys 4 link, Viking coil overs, C6 brakes
Old 08-13-2010, 06:24 AM
CamaroAJ's Avatar
should say DEX III. thats all GM used in all the manual transmissions i have ever worked on.
